the IT team already installed autocad mechanical in my laptop with the license file in the company computer server.
i want to continue edit my drawing at home but that's not possible cause there is no license file in my laptop.
so can i get the lic file ?
regards
Deky Darmawan
Dear ddarmawan,
If you do have a networked license, you can request a separate serial number (Home Use) through our Registration and Activation Team. Kindly complete the form and submit. They will contact your directly regarding your request.
Have a nice day!
Best Regards,
Hi ddarmawan,
Welcome to our forum!
This kind of licensing question is best handled in our Installation & Licensing forum, but let me answer your question.
In addition to Arlin's suggestion, if you installed a network licensed version of Autodesk product, you can borrow a license. Please refer to the following technical solution. Even though it mentions Navisworks, the same workflow applies to AutoCAD Mechanical as well.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15174001&linkID=10382101
Thank you.
Im transferring the license of the autocad LT 2013 through License transfer utility but there is an error below:
Export Request Failed
The serial number you entered is not valid. Try again (1)
click the "Try again" link to resubmit the request.
Try again
Error reference: 1
PLease help me....
email me at ikram_aev981@yahoo.com
