I'm running windows 7 on intel 5 processors and my 2007LT has just told me that the licence needs to be verified and that I have exceeded the permitted number of activations. The PC is new after my previous one failed but I don't really want to upgrade software unless I have to in the current economic climate. Any ideas?
Solved by joane.bonghanoy. Go to Solution.
You will have to call and activate your license instead of doing it at startup: not a big deal for most users with the same issue.
Thanks Dean
I have done this and it ran fine for about three weeks then suddenly started a licence verification on each session start up. Also noticed on trying to re-register it tells me that I have exceeded my permitted number of activations! I didn't know there was such a thing. Will try uninstalling and reinstalling and re-registering from scratch to see if that helkps.
Be aware that R2007 is in no way shape or form supported in Win7, which may be the ultimate problem for you.
not supported=no real fix.
Hi stevep100,
Indeed pendean is correct, AutoCAD 2007 has not been tested and confirmed to be compatible with Windows 7 OS. Please refer to this link for more details on Windows 7 compatibility: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=10676494.
If you are still having activation issue, feel free to contact our Registration and Activation team at 1800-551-1490, M-F, 830am - 530pm. Alternatively, you can Private Message (PM) me your Serial Number so I can look into.
Hi stevep100,
I have already activated your License, using the Request Code provided. You should be receiving that in your email address.
If this has resolved your issue, please click on the Accept as Solution button so it may serve as a reference for other users active in this forum.
Hi again
thanks for your help, it seems to have re-activated and appears stable once more!
Regards
Steve
