> i have just installed vista ultimate 64 from xp 64 and when i first
> installed autocad 2009
> and tried to validate i typed a wrong number.now when i try to open it all
> i get is licence error 1.1.96
The problem you're having is the following:
"-96 Server machine is down or not responding.
See the system administrator about starting the server, or make sure that
you’re referring to the right host (see LM_LICENSE_FILE environment
variable). "
Essentially it says: "make your license path point somewhere valid".
> I have re-installed autocad 2009 around 10 times now and still get the
> same error when i try to open it.
If you asked before then you could have saved 9 of the installations 🙂
Best regards,
Henrik Goldman
Flexlm license management to reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Knowledgebase on software license management - http://kb.x-formation.com/
Protect your software with LM-X License Manager -
http://www.x-formation.com/lm-x_license_manager/index.html
