Installation & Licensing
colin63
1777 Views, 5 Replies
licence error1.1.96
i have just installed vista ultimate 64 from xp 64 and when i first installed autocad 2009 and tried to validate i typed a wrong number.now when i try to open it all i get is licence error 1.1.96 I have re-installed autocad 2009 around 10 times now and still get the same error when i try to open it.
Can someone please help.
5 REPLIES 5
in reply to: colin63
The problem you're having is the following:
"-96 Server machine is down or not responding.
See the system administrator about starting the server, or make sure that
you’re referring to the right host (see LM_LICENSE_FILE environment
variable). "
Essentially it says: "make your license path point somewhere valid".
If you asked before then you could have saved 9 of the installations 🙂
Best regards,
Henrik Goldman
Flexlm license management to reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Knowledgebase on software license management - http://kb.x-formation.com/
Protect your software with LM-X License Manager -
http://www.x-formation.com/lm-x_license_manager/index.html
colin63
Dear Henrik,
Thanks for the help but can you please help me to create a valid path
thanks
colin
Typically you would set an environment variable like LM_LICENSE_FILE to:
LM_LICENSE_FILE = c:\my\license\app.lic
Or if you're using a network license then to the license server: port@host
Best regards,
Henrik Goldman
colin63
sorry i need to know what exactly to type when setting up a new environment variable this is a standalone installation in c:\ program files
thanks
colin
Bob Holland
Call or e-mail me and I will walk you through setting the variable.
Bob Holland
Bob Holland Consulting
bob@bobhollandconsulting.com
Administrator Productivity
