Installation & Licensing
just installed Inventor 2012 at work but fusion plugin missing
1 REPLY 1
longoriaos
1394 Views, 1 Reply
Hi, I hope some can help
I just installed inventor suite 2012 which i believe should have fusion plugin inside inventor but is not there
we do have fusion as a separate program but no the plugin inside inventor
I have a student version at home of inventor 2012 and it does have the plugin
should i reinstall the program?
1 REPLY 1
emily.xu
in reply to: longoriaos
First, can you find the Fusion for Inventor Add-in in the Control Panel?
Also, can you see the Edit Form icon in Inventor?
If no,maybe you have not install the add-in,I would suggest you to run setup.exe and then configure to install it.
Emily Xu
Product Support
Administrator Productivity
