Installation & Licensing
inventor2014Ita missing file
10 REPLIES 10
Message 1 of 11
valeloru
4908 Views, 10 Replies
Hi everyone,
I downloaded the italian version of Inventor 2014.
The name of file is: Autodesk_Inventor_2014_Ita_64bit_dlm_001_002.sfx  (3,93 GB)
When I go to install it says missing files.
Where is this missing file?
Please, help me.
Thank you
10 REPLIES 10
Message 2 of 11
asburyj
in reply to: valeloru
The inventor download is broken into two parts. When you choose a browser download it should start downloading both. One should end with _001_002 and the other ends with _002_002
To save you a little trouble I have generated a direct download link to that 2nd part. You can trigger the download with the link below
http://efulfillment.autodesk.com/SWDLDNET3/2014/INVNTOR/DLM/Autodesk_Inventor_2014_Italian_64bit_dlm...
Jeffry Asbury
Message 3 of 11
valeloru
It works!!!
I downloaded the second file and there isn't the error message now! finally!
Thank you very much!!!
Have a good day.
Message 4 of 11
akhan0579
in reply to: asburyj
why do i need a subscribtion to down load it if it is free
Message 5 of 11
Darrenpearson
Hi I have a similar issue when attempting to dowload the enligsh language version. However I can only download part 2 (Autodesk_Inventor_2015_English_Win_64bit_R1_dlm_002_002.sfx) and do not seem to have the option to download part one.
Would you be able to provide a direct download link to Inventor part one.
Message 6 of 11
asburyj
in reply to: Darrenpearson
Both parts of the English Inventor download are available on the virtual agent if needed. Here are the steps to find it the direct download links. Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk... Select the 2nd Choice "Download Links " Select your product You are now presented with the choice to download your software.
Jeffry Asbury
Message 7 of 11
gabor.kleinheincz
similar isssue for me, with this file:
Autodesk_3ds_Max_2016_EFGJKS_Win_64bit_dlm_001_002.sfx.exe
But it seems (from the name at least "001_002") that it contains both parts...
Message 8 of 11
asburyj
in reply to: gabor.kleinheincz
The 001_002 in the file name means file 1 of 2. If you are missing part 2 you can download it from the virtual agent using the instructions posted above.
Jeffry Asbury
Message 9 of 11
ulyana_pavlova
please, can you post ones again link to 002 file? The preveuse one doesnt work anymore. Thanks
Message 10 of 11
asburyj
in reply to: ulyana_pavlova
You wanted the italian version like what was originally requested in the thread? If so here's a link
Jeffry Asbury
Message 11 of 11
ulyana_pavlova
Oh sorry no, didnt see it! I want English please.
Thank you.
Administrator Productivity
