Installation & Licensing
inventor 2011 install on other partition than c
8 REPLIES 8
Message 1 of 9
847 Views, 8 Replies
how to install inventor 2011 on other partition than c? I've changed directiries that i can see in installator, but it still needs over 2GB on C partition
8 REPLIES 8
Message 2 of 9
aaronhai
Hi genek1,
Welcome to Autodesk Discussion Group.
Please refer to this article written by Autodesk Expert Elite and see if it address your concerns.
Thank you.
Aaron Hai
Message 3 of 9
in reply to: aaronhai
so there is no solution for that? Except clear space and mowing temp file. And these 2 GB are some junk that is stored in temp file and after that i can delete it?
Message 4 of 9
TravisNave
Correct.  It is the space that Windows needs to install that large program.  It should be cleanable.  Keep in mind that if you install materials libraries in SQL, then it will likely default to C:\ as well.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 5 of 9
in reply to: TravisNave
I've installed it and clean temp folder and disk space is still taken, so inventor still install something on C, but i changed every path in install program that i can find
Message 6 of 9
TravisNave
How much space?
There's always going to be things on C:\ like registry, icons, profile registrations and shortcuts, Windows installer information, so on and so forth.
Autodesk Forums:
Message 7 of 9
about 2GB, much more than few shortcuts etc need
Message 8 of 9
TravisNave
Did you install the materials library?  This will install SQL Server and content library databases to your C:\.
Autodesk Forums:
Message 9 of 9
Maybe. I installed default components except service packs. Materials library are not necessary? It can't be install on other partition?
Administrator Productivity
