how to install inventor 2011 on other partition than c? I've changed directiries that i can see in installator, but it still needs over 2GB on C partition
so there is no solution for that? Except clear space and mowing temp file. And these 2 GB are some junk that is stored in temp file and after that i can delete it?
Correct. It is the space that Windows needs to install that large program. It should be cleanable. Keep in mind that if you install materials libraries in SQL, then it will likely default to C:\ as well.
How much space?
There's always going to be things on C:\ like registry, icons, profile registrations and shortcuts, Windows installer information, so on and so forth.
Did you install the materials library? This will install SQL Server and content library databases to your C:\.
