after downloading and extracting the files. the setup promt appears. After clicking run it goes away. In my event log it show a side by side configuration error. What do i need to do. Below is the error message from my event log
#59.
C:\Autodesk\AutoCAD_2012_English_Win_64bit\Setup\SetupUi.dll |
C:\Windows\WinSxS\manifests\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57.manifest |
0 |
Please try to uninstall Microsoft Visual C++ 2008 Runtime and install it from here.
http://www.microsoft.com/download/en/details.aspx?id=5582
If you still get the error, please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
Please try to clean the VC++ runtime, Uninstall all the versions from the Add/remove programs and install from the MS site
32 bit and 64bit OS
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5638
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5582
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5555
64-bit OS only
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=18471
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=2092
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=14632
If this fails please reinstall .net framework also.
