Attempting to deploy Revit Arch 2012 from a deployment image. (XP 32bit x86 )
The Deployment image appeared to finish building correctly no error's reported
so now installing from this deploy build to a test pc ...
The installer fails / stalls after material library is installed
Any clues ?
log below:-
2012/2/17:11:44:56 Administrator C-0030-1735570 === Setup started on C-0030-1735570 by Administrator ===
2012/2/17:11:44:56 Administrator C-0030-1735570 Launch
2012/2/17:11:45:35 Administrator C-0030-1735570 Autodesk® Revit® Architecture 2012 : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Autodesk® Design Review 2012 : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Autodesk Material Library 2012 - Medium Image Library : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Internet Explorer 7 : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 Redistributable (x64) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2005 Redistributable (x86) : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2005 Redistributable (x64) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 Redistributable (x86) : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (ATL) (x86) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (MFC) (x86) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (CRT) (x86) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (ATL) (x64) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (MFC) (x64) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (CRT) (x64) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 .NET Framework Runtime 3.5 SP1 : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 .NET Framework Runtime 3.5 SP1 Language Pack : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 .NET Framework Runtime 4.0 : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 DirectX® Runtime : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 .NET Framework Runtime 2.0 : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 FaroSDK : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 VSTA aide : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 VSTA art : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft VSTA Dependencies (x64) - ENU : INSTALLSTATE_NOT_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 SSE2 Support Check : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2008 SP1 Redistributable (x86) : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Microsoft Visual C++ 2010 Redistributable (x86) : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Autodesk Material Library 2012 : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Autodesk Material Library 2012 - Base Image Library : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 Autodesk Material Library 2012 - Low Image Library : INSTALLSTATE_INSTALLED
2012/2/17:11:45:35 Administrator C-0030-1735570 === Setup ended ===
2012/2/17:11:44:53 Administrator C-0030-1735570 === Setup started on C-0030-1735570 by Administrator ===
2012/2/17:11:44:53 Administrator C-0030-1735570 Launch
2012/2/17:11:45:36 Administrator C-0030-1735570 === Setup ended ===
