• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    installing error
    267 Views, 11 Replies
    10-08-2012 07:51 AM
    the error below is what i am getting after i have already downloaded and click to installt o my laptop, and right when its almost done opening the ziped files, it gives me that error.... please fix ur copy of revit 2011 in the downloads so i can download the clean copy...
    CRC failed in support\dotnetfx\wcu\dotNetFramework\dotNetFX35\x64\netfx35_x64.exe
    Unexpected end of archive
    Please use plain text.
    TravisNave
    Re: installing error
    10-08-2012 08:09 AM in reply to: cyco135
    Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
    For more detailed information on this process, please see the following blog post tip here:
    http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
    Active Member
    10-08-2012 09:18 AM in reply to: cyco135
    tis is wat it says
    Active Member
    10-08-2012 09:19 AM in reply to: TravisNave
    i ae used google rome, and internet exployer, and monzilla firefox, and same ting...
    Active Member
    10-08-2012 09:22 AM in reply to: cyco135
    tis is wat i see
    TravisNave
    10-08-2012 09:30 AM in reply to: cyco135
    Try downloading from another computer.  Make sure your real-time antivirus is disabled.
    Active Member
    10-08-2012 03:16 PM in reply to: TravisNave
    i am not pc stupid, jsut to let u know, i have tried it from 5 different pc's, and on each one, on google chrome and on firefox, as well as the 2 class instructors have tried, and we get that same issue, from all the computers, and diffrent people have logged in with thier accounts, and they got the same errors...
    Active Member
    10-08-2012 10:29 PM in reply to: cyco135
    still same thing, and tried it of 3 different computers , i am not getting happy bout this
    TravisNave
    10-09-2012 06:58 AM in reply to: cyco135
    I did not say you were stupid.  I understand that you are frustrated. I would be too. If you have done all that you've said you've done then likely the download itself on the server is corrupted.  Have you tried downloading the trial?  It will activate just the same.  Otherwise, perhaps philip.s will see this thread and provide a corrected link.
    philip.s
    Re: installing error - CRC failed - Corrupt Installation Files
    10-09-2012 04:18 PM in reply to: TravisNave
    Thanks Travis.
    Antonio, I was just able to successfully download and install Revit Architecture 2011 from the Education Community, so I can't confirm a server issue, however this is generally one of the "busy seasons" which would result in increased traffic and potentially slower speeds.
    As Travis mentioned, I can provide a timed direct download link as a potential workaround. Please try again using the following and let us know if it resolves the issue.
    Autodesk Revit Architecture 2011 32-64 BIT
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
