Currently using civil 3d infrastructure. When it was installed, 3ds max was not included in the installation. Well, now I need it installed. Do i have to install the entire suite again to get it, or is there a way to just install the 1 program? Thanks
Solved by TravisNave. Go to Solution.
No, not the whole suite. The other applications will already show as installed when you run setup again. You can choose only to install Max. Good Luck!
