Installation & Licensing
installing civil 3d infrastructure
1 REPLY 1
MKH-VB
266 Views, 1 Reply
Currently using civil 3d infrastructure. When it was installed, 3ds max was not included in the installation. Well, now I need it installed. Do i have to install the entire suite again to get it, or is there a way to just install the 1 program? Thanks
mkh
1 REPLY 1
TravisNave
in reply to: MKH-VB
No, not the whole suite.  The other applications will already show as installed when you run setup again.  You can choose only to install Max.  Good Luck!
Autodesk Forums:
Administrator Productivity
