• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    VANDENBOSDESIGN
    installing autocad lt 2002
    636 Views, 3 Replies
    09-29-2010 02:06 PM
    I recently purchased a new laptop and tried to install autocad lt 2002 on it. I can get the program to run but I keep getting script errors. Is this because of my operating system? I also tried downloading a service pack for the program, then I had to uninstall and reinstall.
    Please use plain text.
    TravisNave
    Re: installing autocad lt 2002
    09-29-2010 02:25 PM in reply to: VANDENBOSDESIGN
    My goodness, probably!  This is a very old release.  It wouldn't be supported on Windows Vista or Windows 7.  It may not even be supported on Windows XP SP3, for that matter...  And definitely nothing 64-bit.
    What OS are you running?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    bensonandbrown
    10-12-2010 11:50 PM in reply to: VANDENBOSDESIGN
    We have loaded AutoCAD LT 2002 onto our new laptop and get error messages after using the program for a short period of time (about 2 minutes), after which time the program shuts down or freezes.
    Is this a conflict with Windows 7?
    Is there anything we can do to fix this?
    DarrenP
    10-13-2010 06:27 AM in reply to: bensonandbrown
    yes windows 7 is not supported with that old of software
    nope you need to get off 2002
