i know that this is not best autodesk practice, but this is what i have need to do, because my software installation program that we use in the company i work. we use a program from capasystems called "capa installer".
now this means that the path that i need to install the program from is like this:
\\ds1\devcontainer$\ComputerJobs\Autocad - Inventor 2011 Clean\v1.0\Kit
and that is where i have my AdminImage folder.
i was able to trick Autocad - Architecture 2011 by using a trick that i found here:
http://forums.autodesk.com/t5/Installation-Licensing/Create-Deployment-FAILS/m-p/2768274
but this was not enough to make Autocad - Inventor 2011 want to install.
is there any help to be gained here for solving my problem?
i've tested a manuel install from a shortened path which works, and a manual test from the long path which doesn't, so i know that "capa installer" won't be able to do any better, please help.
the error i keep getting is 1603
Try removing spaces from the path. I have had problems with previous version installs when there are spaces it would fail.
the problem is not the spaces, the problem is the long file paths, deleting the spaces alone unfortunaly will not fix anything, all the other installers of this type can compensate for this. My problem is that the deplyment image makes this sort of long names:
\AdminImage\x86\Inventor\Application Data\Autodesk\Inventor 2011\Tutorial Files\Mold\CoverMold\Cover Mold\Sliders\GENERIC_Generic Single Locking 1 1\CoverMold_cover_SA1_Generic1 Angle Pin.ipt
thats 192 chars, alone for the first file that is giving me problems. and the most my program will take is 240 chars for a path name, and then 260 chars for the file name all in all, and autocad are using all of those by playing 'database' with it's files.
