Installation & Licensing
Member
Message 1 of 6 (326 Views)
installation problem
326 Views, 5 Replies
09-19-2013 01:47 AM
when i install the AutoCAD 2014......there is a new window mentioned "internal error 2738"
Product Support
Message 2 of 6 (290 Views)
Re: installation problem
09-20-2013 06:14 AM in reply to: one11one11one
Sorry to hear that you're having problems installing AutoCAD 2014, this issue may result on some wrong registration of the VBScript.
Check the Autodesk knowledge Database for a resolution proposition "Installation fails with message "Error 2738. Could not access VBScript run time for custom action"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15102758&linkID=9240617
If it doesn't help you to fix the issue, have a look at the following blog post "Error 2738 Installation,".
http://upandready.typepad.com/up_and_ready/2011/07/error-2738-installation-could-not-access-vbscript...
That should help to resolve your issue.
Cheers
Yannick Karawa
Member
Message 3 of 6 (254 Views)
09-23-2013 09:35 AM in reply to: Yannick.Karawa
thanks......i can install sucessfully....
but
when i launch the programme...there's a problem...
"FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at e7800004h"
*Expert Elite*
TravisNave
Message 4 of 6 (251 Views)
09-23-2013 09:41 AM in reply to: one11one11one
Sounds like it could be a .NET Framework corruption issue.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Product Support
byron.morales
Message 5 of 6 (232 Views)
09-23-2013 04:03 PM in reply to: TravisNave
You can also reset AutoCAD as follows:
http://upandready.typepad.com/up_and_ready/2012/07/the-easiest-way-to-reset-autocad.html
Let us know the Results.
Byron Morales
Member
Message 6 of 6 (180 Views)
09-27-2013 05:28 AM in reply to: one11one11one
the problems still in here
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
