Installation & Licensing
one11one11one
652 Views, 5 Replies
installation problem
when i install the AutoCAD 2014......there is a new window mentioned "internal error 2738"
5 REPLIES 5
Sorry to hear that you're having problems installing AutoCAD 2014, this issue may result on some wrong registration of the VBScript.
Check the Autodesk knowledge Database for a resolution proposition "Installation fails with message "Error 2738. Could not access VBScript run time for custom action"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15102758&linkID=9240617
If it doesn't help you to fix the issue, have a look at the following blog post "Error 2738 Installation,".
http://upandready.typepad.com/up_and_ready/2011/07/error-2738-installation-could-not-access-vbscript...
That should help to resolve your issue.
Cheers
Yannick Karawa
thanks......i can install sucessfully....
but
when i launch the programme...there's a problem...
"FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at e7800004h"
TravisNave
in reply to: one11one11one
Sounds like it could be a .NET Framework corruption issue.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
byron.morales
in reply to: TravisNave
You can also reset AutoCAD as follows:
http://upandready.typepad.com/up_and_ready/2012/07/the-easiest-way-to-reset-autocad.html
Let us know the Results.
Byron M.
the problems still in here
Administrator Productivity
