Installation & Licensing
installation problem max 2013
4 REPLIES 4
2260 Views, 4 Replies
hi, i'm a student.. studying interior design..
i'm trying to install max 2013 getting a message like this :
                                        ''the library could not be installed/uninstalled. please exit all running applications and try again.''
i tried several times but it didn't work ... hope you have the solution.. thanks...
4 REPLIES 4
i solved the problem.... Smiley Happy
pvillella
We're having this same issue. What was your solution?
Patrick  Villella, LEED AP
AEC Technical Consultant
_______________________________________
www.cadsoft-consult.com
Blog: What's the Word on BIM? www.cadsoft-consult.com/blogs/architecture
in reply to: pvillella
sorry for delay..
                 here is my solution : extract the content of the .exe folder that you have downloaded before (Autodesk_3ds_Max_2013_EFGKJS_Win_32bit.exe).
               İnside this folder , follow this line ; Content / ADSKMaterials / 2013 / .. you 'll find 3 folders in ''2013'',  CM, ILB and ILM.. each one has a .msi file.
              Manually install the .msi files ( MaterialLibrary2013.msi, BaseImageLibrary2013.msi, MediumImageLibrary2013.msi).
              Then install max 2013 setup.exe. İf you take a message like this; ''there is no .msi files in this folder'' or something else, ignor this message then finish installation..
                                   this way worked for me ..
        sorry for my bad english... 🙂
I still have problems!! the message about applications open appears also when i try to install the file mediumimagelibrary.. Can you help me??
Administrator Productivity
