Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
installati on problem. Viewports show desktop!
- Highlight
- Email to a Friend
Just installed 3ds Max 2010 educational version in windows 7. When I opened it the viewports were transparent.... basically I see through them whatever I have in my desktop, folders or other programs... The attached image I think it explains it better.
Any thoughts?
Cheers. Jorge
NOTE: My computer is a Lenovo T61P, core duo 2.50ghz, RAM 3gb, no idea which graphic card but Maya 2011 works perfectly.
Re: installati on problem. Viewports show desktop!
- Highlight
- Email to a Friend
Hi Jorge
This problem normally occurs if you have the display configuration set to either OpenGL or Direct3D and your graphics card does not completely support OpenGL or Direct3D OR you may not have updated drivers for your graphic card.
By default Max 2010 will use DirextX display, You can switch MAX to openGL Windows Start > All Programs > Autodesk> Autodesk 3ds max 2010 > Change Graphics Mode. Revert from Dirext x and Choose Open GL and see if that works.
Here is the link for Certified Hardware and tested drivers you can check and Update your graphic driver to certified one http://usa.autodesk.com/adsk/servlet/index?siteID=
I hope this helps.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Cheers
Anil Choudhary
Product Support Specialist
Autodesk, Inc.
