I'd start by looking here:
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
None of this makes any sense. How can I get in touch with support from directly from Autodesk rather than going on a wild goose chase?
Thank you!
There is support called Up and Ready support http://usa.autodesk.com/support-offerings/up-and-ready/ The problem is they say they will give you instructions on how to use Up & Ready support once you activate your product but you cannot activate your product because if you cant open it you cant get an activation code. Any ideas on where to go from here?
Thanks for the help!
Hi thomas4611,
By your latest post, am I correct with my assumption that you are having issues activating your License? If so, what is the error message?
Otherwise, do reply back with more details so I can help you sort this out.
Yes, both Revit Architecture 2013 and Autocad 2013 were recently installed. Both open for 1 second and automatically close. I only have a serial number and product key and no activation code. I checked my computer it is 64 bit and the installation was for 64 bit
