Installation & Licensing
installation of autocad failed.
2 REPLIES 2
kiyagaedwin
1207 Views, 2 Replies
I have failed to install install autocad. The problem is that the languge packs are already installed. I dont know how to remove them because it  fails at the langugage packs section. Here is the log.
2012/5/13:07:54:41 drake DRAKE-PC === Setup started on DRAKE-PC by drake ===
2012/5/13:07:54:41 drake DRAKE-PC Launch
2012/5/13:07:54:49 drake DRAKE-PC PageOpen LaunchDialog
2012/5/13:07:54:51 drake DRAKE-PC PageOpen LicenseDialog
2012/5/13:07:54:53 drake DRAKE-PC PageOpen ProductInfoDialog
2012/5/13:07:55:05 drake DRAKE-PC PageOpen ProductSelectionDialog2
2012/5/13:07:55:07 drake DRAKE-PC PageOpen FullProgressDialog
2012/5/13:07:55:07 drake DRAKE-PC Installing DirectX Runtime: G:\3rdParty\DirectX\DXSETUP.exe /silent
2012/5/13:07:55:27 drake DRAKE-PC Install DirectX Runtime Succeeded
2012/5/13:07:55:27 drake DRAKE-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\drake\AppData\Local\Temp\_AID355.tmp\Media.mst"
2012/5/13:08:01:30 drake DRAKE-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/5/13:08:01:30 drake DRAKE-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="G:\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\drake\AppData\Local\Temp\_AID355.tmp\Media.mst"
2012/5/13:08:01:37 drake DRAKE-PC Install Autodesk Content Service Succeeded
2012/5/13:08:01:37 drake DRAKE-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="G:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\drake\AppData\Local\Temp\_AID355.tmp\Media.mst"
2012/5/13:08:01:46 drake DRAKE-PC Install Autodesk Content Service Language Pack Succeeded
2012/5/13:08:01:46 drake DRAKE-PC Installing AutoCAD® 2013: TRANSFORMS="G:\x64\en-us\acad\acad.mst;C:\Users\drake\AppData\Local\Temp\_AID355.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/13:08:06:02 drake DRAKE-PC Install AutoCAD® 2013 Succeeded
2012/5/13:08:06:03 drake DRAKE-PC Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\drake\AppData\Local\Temp\_AID355.tmp\_la49E0.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="G:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/5/13:08:06:03 drake DRAKE-PC Install AutoCAD® 2013 Language Pack Failed Installation aborted, Result=1624
2012/5/13:08:06:49 drake DRAKE-PC Rollback AutoCAD® 2013 Succeeded
2012/5/13:08:06:52 drake DRAKE-PC Rollback Autodesk Content Service Language Pack Succeeded
2012/5/13:08:06:57 drake DRAKE-PC Rollback Autodesk Content Service Failed Failure is ignored, Result=1603
2012/5/13:08:06:57 drake DRAKE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/5/13:08:06:57 drake DRAKE-PC PageOpen InstallCompleteDialog
2012/5/13:08:07:04 drake DRAKE-PC === Setup ended ===
2012/5/13:08:26:07 drake DRAKE-PC === Setup started on DRAKE-PC by drake ===
2012/5/13:08:26:07 drake DRAKE-PC Launch
2012/5/13:08:26:45 drake DRAKE-PC === Setup ended ===
2 REPLIES 2
cdbell
in reply to: kiyagaedwin
I am seeing the same thing:
Install AutoCAD Electrical 2013 Language Pack Failed Installation aborted, Result=1624
Any suggesting.
mail
Install    AutoCAD Civil 3D 2013 Language Pack    Failed    Installation aborted, Result=1624
Does anyone have any ideas?
Administrator Productivity
