Installation & Licensing
installation of Inventor 10 (2005) on Windows 7
5 REPLIES 5
4416 Views, 5 Replies
I just upgraded my computer from an XP system to Windows 7 Pro and am trying to install my Inventor 10 (2005 Release) on it.  I thought I should be able to install and run in Windows 7 Pro with Compatability Mode.  When i install the DVD, I get the following error:  Microsoft WSE 2.0 Runtime Error: 1001. Then install is aborted.  It seems to me the program should atleast upload, even if it won't run??  Anyone still running XP era Inventor on Windows 7?  If so, how?  Thx,  Shaun
5 REPLIES 5
emily.xu
We support Inventor 2010 SP1 and later version running on Windows 7 officially, see our system requirement for Inventor products:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15402497&linkID=9242018
So suggest you to upgrade your Inventor.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
aaronhai
Inventor 10 is only supported on Win XP and 200 (32 bit).
Refer- http://usa.autodesk.com/getdoc/id=TS14034959
Aaron Hai
aaronhai
in reply to: aaronhai
Looks like this post got both Emily and my attention simulteneously, so I thought I will clarify. 🙂
If you are running on Windows 7, please install Inventor 2010 SP1 or later version
Refer - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15402497&linkID=9242018
If you are on Inventor 10, you need to be on Win XP or Win 2000 (32 bit).
Thanks.
Aaron Hai
so finally, the question is can i install inventor 10 on windows7 ?
Mark.Lancaster
@Anonymous
No this is not possible.  You may get it installed but most likely it will not function.  Why do you need a 13 yr old product?
Mark Lancaster
Administrator Productivity
