• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Contributor
    Accepted Solution
    installation failures with Building Design Suite Ultimate 2013 - 1603 & 1619
    923 Views, 5 Replies
    11-30-2012 05:37 PM
    I’m getting errors 1619 and 1603 when trying to install some files from the Building Design Suite Ultimate 2013. I’m installing this from an Autodesk stick drive on a local machine.
    Many of the programs have installed, and some have not – Autodesk Quantity Takeoff 2013, AutoCAD Architecture 2013, AutoCAD MEP 2013, AutoCAD Structural Detailing 2013, Autodesk Infrastructure Modeler 2013 have not installed.
    The other software in the package has installed and is running – ACAD, Revit, 3ds Max, Inventor, etc.
    Here is the log from just the ACAD Arch install;
    2012/11/30:18:05:33      mpp     MPP2   === Setup started on MPP2 by mpp ===
    2012/11/30:18:05:33      mpp     MPP2   Launch
    2012/11/30:18:05:44      mpp     MPP2   === Setup ended ===
    2012/11/30:18:05:35      mpp     MPP2   === Setup started on MPP2 by mpp ===
    2012/11/30:18:05:35      mpp     MPP2   Launch
    2012/11/30:18:05:43      mpp     MPP2   Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
    2012/11/30:18:05:43      mpp     MPP2   Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
    2012/11/30:18:05:43      mpp     MPP2   PageOpen       LaunchDialog
    2012/11/30:18:06:38      mpp     MPP2   PageOpen       LicenseDialog
    2012/11/30:18:06:41      mpp     MPP2   PageOpen       ProductInfoDialog
    2012/11/30:18:07:48      mpp     MPP2   PageOpen       ProductSelectionDialog2
    2012/11/30:18:08:03      mpp     MPP2   PageOpen       FullProgressDialog
    2012/11/30:18:08:03      mpp     MPP2   Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
    2012/11/30:18:08:34      mpp     MPP2   Install   DirectX® Runtime         Succeeded
    2012/11/30:18:08:34      mpp     MPP2   Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
    2012/11/30:18:08:38      mpp     MPP2   Install   FaroSDK           Succeeded
    2012/11/30:18:08:39      mpp     MPP2   Installing AutoCAD® Architecture 2013:  TRANSFORMS="H:\x64\en-us\ACA\ACA.mst;C:\Users\mpp\AppData\Local\Temp\_AIBE5F.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
     2012/11/30:18:09:43     mpp     MPP2   Install   AutoCAD® Architecture 2013  Failed   Installation aborted, Result=1603
    2012/11/30:18:09:43      mpp     MPP2   Rollback          DirectX® Runtime         Failed   Failure is ignored, Result=1619
    I could be missing it, but I’m not seeing anything related to C++. I see there is a Direct X Runtime failure.
    Any suggestions – greatly appreciated in advance! mpp
    Please use plain text.
    Product Support
    emily.xu
    Re: installation failures with Building Design Suite Ultimate 2013 - 1603 &
    12-03-2012 02:05 AM in reply to: mpukas
    See if this solution can solve your problem.
    Emily Xu
    AutodeskCare | Product Support
    Autodesk, Inc.
    Active Contributor
    12-04-2012 01:33 PM in reply to: emily.xu
    Thanks for the reply and link, Emily.
    I reviewed that solution, but I don't think that was my problem as I hadn't yet installed service pack 1.1
    I ended up resintalling the OS and all software. I did the Buildign Design Suite files before I installed anything else, and it all installed and is working fine.
    Thanks again. mpp
    Member
    01-21-2013 04:18 AM in reply to: mpukas
    I am experiencing total frustration with installing BDSU 2013 on Win 7 64 bit. Install media is Autodesk USB drive, stand alone install.
    I have tried several suggested methods many times including disconnecting the internet connection, disabling ant-virus.
    Copying the contents of USB to the hardrive failed as well, citing file errors.
    On a positive note, I attempted an install on a similar machine with the USB drive and I was able to get past the Revit install at least with success. I did not persue the full install however due to time constraints.
    Please help, I'm lost with what to do next. I have attached the most recent install log.
    thank you
    Member
    02-05-2013 09:08 AM in reply to: melzer51
    I too previously installed several programs. Now I'm trying to add others and they won't install. I've followed advice of others to no avail. Modified the setup.ini file to delete the prerequisite request for framework. Removed sp1.1 except for map3d and civil 3d. They would have to be completely uninstalled. Here is the log file for AutoCAD Architecture 2013: (Windows 8, 64-bit)
    2013/2/5:10:45:29 Poz POZ_WORKSTATION === Setup started on POZ_WORKSTATION by Poz ===
    2013/2/5:10:45:29 Poz POZ_WORKSTATION Launch
    2013/2/5:10:45:35 Poz POZ_WORKSTATION === Setup ended ===
    2013/2/5:10:45:33 Poz POZ_WORKSTATION Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
    2013/2/5:10:45:33 Poz POZ_WORKSTATION Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
    2013/2/5:10:45:34 Poz POZ_WORKSTATION PageOpen LaunchDialog
    2013/2/5:10:45:37 Poz POZ_WORKSTATION PageOpen LicenseDialog
    2013/2/5:10:45:42 Poz POZ_WORKSTATION PageOpen ProductInfoDialog
    2013/2/5:10:46:02 Poz POZ_WORKSTATION PageOpen ProductSelectionDialog2
    2013/2/5:10:46:21 Poz POZ_WORKSTATION PageOpen FullProgressDialog
    2013/2/5:10:46:21 Poz POZ_WORKSTATION Installing DirectX® Runtime: E:\Autodesk Building Design Suite\3rdParty\DirectX\DXSETUP.exe /silent
    2013/2/5:10:46:41 Poz POZ_WORKSTATION Install DirectX® Runtime Succeeded
    2013/2/5:10:46:41 Poz POZ_WORKSTATION Installing FaroSDK: E:\Autodesk Building Design Suite\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
    2013/2/5:10:46:46 Poz POZ_WORKSTATION Install FaroSDK Succeeded
    2013/2/5:10:46:46 Poz POZ_WORKSTATION Installing AutoCAD® Architecture 2013: TRANSFORMS="E:\Autodesk Building Design Suite\x64\en-us\ACA\ACA.mst;C:\Users\Paul\AppData\Local\Temp\_AI7FE3.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autodesk Building Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2013/2/5:10:47:38 Poz POZ_WORKSTATION Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603
    2013/2/5:10:47:38 Poz POZ_WORKSTATION Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
    Member
    02-05-2013 10:35 AM in reply to: PPosner
    Temporary Workaround:
    If you look at the log file, AutoCad Architecture is trying to load in Autodesk\AutoCad 2013 where AutoCad (plain) was already installed. By renaming the AutoCad 2013 folder to AutoCad 2013 Plain, ACA loaded and works, the problem is you have to rename the folders temporally to either run the plain version or ACA version.
    Obviously, this isn't how you want things to work. You could uninstall one of the versions then install the one you want.
    The best solution would be to install each application in a folder of your choosing, however; the installer location is greyed out.
    At this point, if someone could at least come up with a way to move folders or rename folders so each program can install and function properly seems like the simplest solution for now.
