Installation & Licensing
Valued Contributor
mpukas
Message 1 of 6 (1,452 Views)
installation failures with Building Design Suite Ultimate 2013 - 1603 & 1619
1452 Views, 5 Replies
11-30-2012 05:37 PM
I’m getting errors 1619 and 1603 when trying to install some files from the Building Design Suite Ultimate 2013. I’m installing this from an Autodesk stick drive on a local machine.
Many of the programs have installed, and some have not – Autodesk Quantity Takeoff 2013, AutoCAD Architecture 2013, AutoCAD MEP 2013, AutoCAD Structural Detailing 2013, Autodesk Infrastructure Modeler 2013 have not installed.
The other software in the package has installed and is running – ACAD, Revit, 3ds Max, Inventor, etc.
Here is the log from just the ACAD Arch install;
2012/11/30:18:05:33      mpp     MPP2   === Setup started on MPP2 by mpp ===
2012/11/30:18:05:33      mpp     MPP2   Launch
2012/11/30:18:05:44      mpp     MPP2   === Setup ended ===
2012/11/30:18:05:35      mpp     MPP2   === Setup started on MPP2 by mpp ===
2012/11/30:18:05:35      mpp     MPP2   Launch
2012/11/30:18:05:43      mpp     MPP2   Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/11/30:18:05:43      mpp     MPP2   Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/11/30:18:05:43      mpp     MPP2   PageOpen       LaunchDialog
2012/11/30:18:06:38      mpp     MPP2   PageOpen       LicenseDialog
2012/11/30:18:06:41      mpp     MPP2   PageOpen       ProductInfoDialog
2012/11/30:18:07:48      mpp     MPP2   PageOpen       ProductSelectionDialog2
2012/11/30:18:08:03      mpp     MPP2   PageOpen       FullProgressDialog
2012/11/30:18:08:03      mpp     MPP2   Installing DirectX® Runtime: H:\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/30:18:08:34      mpp     MPP2   Install   DirectX® Runtime         Succeeded
2012/11/30:18:08:34      mpp     MPP2   Installing FaroSDK: H:\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2012/11/30:18:08:38      mpp     MPP2   Install   FaroSDK           Succeeded
2012/11/30:18:08:39      mpp     MPP2   Installing AutoCAD® Architecture 2013:  TRANSFORMS="H:\x64\en-us\ACA\ACA.mst;C:\Users\mpp\AppData\Local\Temp\_AIBE5F.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="H:\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2012/11/30:18:09:43     mpp     MPP2   Install   AutoCAD® Architecture 2013  Failed   Installation aborted, Result=1603
2012/11/30:18:09:43      mpp     MPP2   Rollback          DirectX® Runtime         Failed   Failure is ignored, Result=1619
I could be missing it, but I’m not seeing anything related to C++. I see there is a Direct X Runtime failure.
Any suggestions – greatly appreciated in advance! mpp
Product Support
emily.xu
Message 2 of 6 (1,419 Views)
Re: installation failures with Building Design Suite Ultimate 2013 - 1603 &
12-03-2012 02:05 AM in reply to: mpukas
See if this solution can solve your problem.
Emily Xu
Valued Contributor
mpukas
Message 3 of 6 (1,392 Views)
12-04-2012 01:33 PM in reply to: emily.xu
Thanks for the reply and link, Emily.
I reviewed that solution, but I don't think that was my problem as I hadn't yet installed service pack 1.1
I ended up resintalling the OS and all software. I did the Buildign Design Suite files before I installed anything else, and it all installed and is working fine.
Thanks again. mpp
Member
melzer51
Message 4 of 6 (1,173 Views)
01-21-2013 04:18 AM in reply to: mpukas
I am experiencing total frustration with installing BDSU 2013 on Win 7 64 bit. Install media is Autodesk USB drive, stand alone install.
I have tried several suggested methods many times including disconnecting the internet connection, disabling ant-virus.
Copying the contents of USB to the hardrive failed as well, citing file errors.
On a positive note, I attempted an install on a similar machine with the USB drive and I was able to get past the Revit install at least with success. I did not persue the full install however due to time constraints.
Please help, I'm lost with what to do next. I have attached the most recent install log.
thank you
Member
PPosner
Message 5 of 6 (1,059 Views)
02-05-2013 09:08 AM in reply to: melzer51
I too previously installed several programs. Now I'm trying to add others and they won't install. I've followed advice of others to no avail. Modified the setup.ini file to delete the prerequisite request for framework. Removed sp1.1 except for map3d and civil 3d. They would have to be completely uninstalled. Here is the log file for AutoCAD Architecture 2013: (Windows 8, 64-bit)
2013/2/5:10:45:29 Poz POZ_WORKSTATION === Setup started on POZ_WORKSTATION by Poz ===
2013/2/5:10:45:29 Poz POZ_WORKSTATION Launch
2013/2/5:10:45:35 Poz POZ_WORKSTATION === Setup ended ===
2013/2/5:10:45:33 Poz POZ_WORKSTATION Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2013/2/5:10:45:33 Poz POZ_WORKSTATION Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2013/2/5:10:45:34 Poz POZ_WORKSTATION PageOpen LaunchDialog
2013/2/5:10:45:37 Poz POZ_WORKSTATION PageOpen LicenseDialog
2013/2/5:10:45:42 Poz POZ_WORKSTATION PageOpen ProductInfoDialog
2013/2/5:10:46:02 Poz POZ_WORKSTATION PageOpen ProductSelectionDialog2
2013/2/5:10:46:21 Poz POZ_WORKSTATION PageOpen FullProgressDialog
2013/2/5:10:46:21 Poz POZ_WORKSTATION Installing DirectX® Runtime: E:\Autodesk Building Design Suite\3rdParty\DirectX\DXSETUP.exe /silent
2013/2/5:10:46:41 Poz POZ_WORKSTATION Install DirectX® Runtime Succeeded
2013/2/5:10:46:41 Poz POZ_WORKSTATION Installing FaroSDK: E:\Autodesk Building Design Suite\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT
2013/2/5:10:46:46 Poz POZ_WORKSTATION Install FaroSDK Succeeded
2013/2/5:10:46:46 Poz POZ_WORKSTATION Installing AutoCAD® Architecture 2013: TRANSFORMS="E:\Autodesk Building Design Suite\x64\en-us\ACA\ACA.mst;C:\Users\Paul\AppData\Local\Temp\_AI7FE3.tmp\x64\ACA\ACA-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\Autodesk Building Design Suite\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/2/5:10:47:38 Poz POZ_WORKSTATION Install AutoCAD® Architecture 2013 Failed Installation aborted, Result=1603
2013/2/5:10:47:38 Poz POZ_WORKSTATION Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Member
PPosner
Message 6 of 6 (1,047 Views)
02-05-2013 10:35 AM in reply to: PPosner
Temporary Workaround:
If you look at the log file, AutoCad Architecture is trying to load in Autodesk\AutoCad 2013 where AutoCad (plain) was already installed. By renaming the AutoCad 2013 folder to AutoCad 2013 Plain, ACA loaded and works, the problem is you have to rename the folders temporally to either run the plain version or ACA version.
Obviously, this isn't how you want things to work. You could uninstall one of the versions then install the one you want.
The best solution would be to install each application in a folder of your choosing, however; the installer location is greyed out.
At this point, if someone could at least come up with a way to move folders or rename folders so each program can install and function properly seems like the simplest solution for now.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
