hello my name sinan. would be a question for you. English text for this moment I do not know I'm writing with the help of google translate. Sorry for spelling errors. AutoCAD 2014 program with the help of my friend's usb hard drive and copied into. After entering the license code to install the installation stops after a short time begins and gives the following error text. microsoftI removed the microsoft c + + programs. I disabled the Windows firewall. I run the setup file as an administrator. I did many similar things, but unfortunately did not happen and I'm a senior software architect 1 I really need to. I also tried another setup files. I downloaded the student license but did not install what I do, unfortunately, but did a lot of research from the internet. With the help as a last resort you would like to help translate. Thank you in advance. w 8.1 operating system x64 single language.
2014/5/1:03:18:35 PC1 PC PageOpen ProductSelectionDialog2
2014/5/1:03:21:36 PC1 PC === Setup ended ===
2014/5/1:03:22:55 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:03:22:55 PC1 PC Path_Length: 155
2014/5/1:03:22:55 PC1 PC Current Directory D:\autocad
2014/5/1:03:22:55 PC1 PC Launch
2014/5/1:03:22:55 PC1 PC CommandLine
2014/5/1:03:22:55 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIAA3C.tmp
2014/5/1:03:22:58 PC1 PC === Setup ended ===
2014/5/1:03:22:57 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:03:22:57 PC1 PC Path_Length: 155
2014/5/1:03:22:57 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIAA3C.tmp
2014/5/1:03:22:57 PC1 PC Launch
2014/5/1:03:22:57 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AIAA3C.tmp\Setup\AcSetup.dll
2014/5/1:03:22:57 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/1:03:22:58 PC1 PC PageOpen LaunchDialog
2014/5/1:03:23:00 PC1 PC PageOpen LicenseDialog
2014/5/1:03:23:02 PC1 PC PageOpen ProductInfoDialog
2014/5/1:03:23:22 PC1 PC PageOpen ProductSelectionDialog2
2014/5/1:03:23:34 PC1 PC PageOpen FullProgressDialog
2014/5/1:03:23:34 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\autocad\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/1:03:24:07 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/1:03:24:07 PC1 PC PageOpen InstallCompleteDialog
2014/5/1:03:32:20 PC1 PC === Setup ended ===
2014/5/1:03:35:12 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:03:35:12 PC1 PC Path_Length: 155
2014/5/1:03:35:12 PC1 PC Current Directory D:\autocad
2014/5/1:03:35:12 PC1 PC Launch
2014/5/1:03:35:12 PC1 PC CommandLine
2014/5/1:03:35:12 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIE953.tmp
2014/5/1:03:35:16 PC1 PC === Setup ended ===
2014/5/1:03:35:14 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:03:35:14 PC1 PC Path_Length: 155
2014/5/1:03:35:14 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIE953.tmp
2014/5/1:03:35:14 PC1 PC Launch
2014/5/1:03:35:14 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AIE953.tmp\Setup\AcSetup.dll
2014/5/1:03:35:14 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/1:03:35:16 PC1 PC PageOpen LaunchDialog
2014/5/1:03:35:35 PC1 PC PageOpen LicenseDialog
2014/5/1:03:35:36 PC1 PC PageOpen ProductInfoDialog
2014/5/1:03:35:57 PC1 PC PageOpen ProductSelectionDialog2
2014/5/1:03:35:59 PC1 PC PageOpen FullProgressDialog
2014/5/1:03:35:59 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\autocad\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/1:03:36:32 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/1:03:36:32 PC1 PC PageOpen InstallCompleteDialog
2014/5/1:03:37:06 PC1 PC === Setup ended ===
2014/5/1:03:43:53 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:03:43:53 PC1 PC Path_Length: 155
2014/5/1:03:43:53 PC1 PC Current Directory K:
2014/5/1:03:43:53 PC1 PC Launch
2014/5/1:03:43:53 PC1 PC CommandLine
2014/5/1:03:43:53 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIDA68.tmp
2014/5/1:03:44:04 PC1 PC === Setup ended ===
2014/5/1:03:43:57 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:03:43:57 PC1 PC Path_Length: 155
2014/5/1:03:43:57 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIDA68.tmp
2014/5/1:03:43:57 PC1 PC Launch
2014/5/1:03:43:58 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AIDA68.tmp\Setup\AcSetup.dll
2014/5/1:03:43:58 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/1:03:44:03 PC1 PC PageOpen LaunchDialog
2014/5/1:03:44:04 PC1 PC PageOpen LicenseDialog
2014/5/1:03:44:06 PC1 PC PageOpen ProductInfoDialog
2014/5/1:03:44:16 PC1 PC PageOpen ProductSelectionDialog2
2014/5/1:03:44:17 PC1 PC PageOpen FullProgressDialog
2014/5/1:03:44:18 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "K:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/1:03:44:50 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/1:03:44:52 PC1 PC PageOpen InstallCompleteDialog
2014/5/1:03:44:57 PC1 PC === Setup ended ===
2014/5/1:23:14:53 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:23:14:53 PC1 PC Path_Length: 155
2014/5/1:23:14:53 PC1 PC Current Directory D:\autocad
2014/5/1:23:14:53 PC1 PC Launch
2014/5/1:23:14:53 PC1 PC CommandLine
2014/5/1:23:14:53 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI4F24.tmp
2014/5/1:23:15:06 PC1 PC === Setup ended ===
2014/5/1:23:14:56 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:23:14:56 PC1 PC Path_Length: 155
2014/5/1:23:14:56 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI4F24.tmp
2014/5/1:23:14:56 PC1 PC Launch
2014/5/1:23:14:57 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI4F24.tmp\Setup\AcSetup.dll
2014/5/1:23:14:57 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/1:23:15:06 PC1 PC PageOpen LaunchDialog
2014/5/1:23:15:38 PC1 PC PageOpen LicenseDialog
2014/5/1:23:15:40 PC1 PC PageOpen ProductInfoDialog
2014/5/1:23:16:00 PC1 PC PageOpen ProductSelectionDialog2
2014/5/1:23:21:53 PC1 PC === Setup ended ===
2014/5/1:23:27:11 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:23:27:11 PC1 PC Path_Length: 155
2014/5/1:23:27:11 PC1 PC Current Directory K:
2014/5/1:23:27:11 PC1 PC Launch
2014/5/1:23:27:11 PC1 PC CommandLine
2014/5/1:23:27:11 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI9437.tmp
2014/5/1:23:27:22 PC1 PC === Setup ended ===
2014/5/1:23:27:15 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:23:27:15 PC1 PC Path_Length: 155
2014/5/1:23:27:15 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI9437.tmp
2014/5/1:23:27:15 PC1 PC Launch
2014/5/1:23:27:16 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI9437.tmp\Setup\AcSetup.dll
2014/5/1:23:27:16 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/1:23:27:22 PC1 PC PageOpen LaunchDialog
2014/5/1:23:27:23 PC1 PC PageOpen LicenseDialog
2014/5/1:23:27:24 PC1 PC PageOpen ProductInfoDialog
2014/5/1:23:27:31 PC1 PC PageOpen ProductSelectionDialog2
2014/5/1:23:27:33 PC1 PC PageOpen FullProgressDialog
2014/5/1:23:27:33 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "K:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/5/1:23:27:36 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/5/1:23:27:36 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "K:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/1:23:28:09 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/1:23:28:10 PC1 PC PageOpen InstallCompleteDialog
2014/5/1:23:33:15 PC1 PC === Setup ended ===
2014/5/1:23:33:27 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:23:33:27 PC1 PC Path_Length: 155
2014/5/1:23:33:27 PC1 PC Current Directory D:\autocad
2014/5/1:23:33:27 PC1 PC Launch
2014/5/1:23:33:27 PC1 PC CommandLine
2014/5/1:23:33:27 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI5193.tmp
2014/5/1:23:33:32 PC1 PC === Setup ended ===
2014/5/1:23:33:30 PC1 PC === Setup started on PC by PC1 ===
2014/5/1:23:33:30 PC1 PC Path_Length: 155
2014/5/1:23:33:30 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI5193.tmp
2014/5/1:23:33:30 PC1 PC Launch
2014/5/1:23:33:30 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI5193.tmp\Setup\AcSetup.dll
2014/5/1:23:33:30 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/1:23:33:32 PC1 PC PageOpen LaunchDialog
2014/5/1:23:33:33 PC1 PC PageOpen LicenseDialog
2014/5/1:23:33:34 PC1 PC PageOpen ProductInfoDialog
2014/5/1:23:33:40 PC1 PC PageOpen ProductSelectionDialog2
2014/5/1:23:33:42 PC1 PC PageOpen FullProgressDialog
2014/5/1:23:33:42 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\autocad\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/1:23:34:14 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/1:23:34:16 PC1 PC PageOpen InstallCompleteDialog
2014/5/1:23:35:01 PC1 PC === Setup ended ===
2014/5/2:00:01:45 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:01:45 PC1 PC Path_Length: 155
2014/5/2:00:01:45 PC1 PC Current Directory K:
2014/5/2:00:01:45 PC1 PC Launch
2014/5/2:00:01:45 PC1 PC CommandLine
2014/5/2:00:01:45 PC1 PC An instance of setup is already running. Only one instance of setup can run at a time.2014/5/2:00:01:47 PC1 PC === Setup ended ===
2014/5/2:00:02:09 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:02:09 PC1 PC Path_Length: 155
2014/5/2:00:02:09 PC1 PC Current Directory K:
2014/5/2:00:02:09 PC1 PC Launch
2014/5/2:00:02:09 PC1 PC CommandLine
2014/5/2:00:02:09 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI8DD2.tmp
2014/5/2:00:02:14 PC1 PC === Setup ended ===
2014/5/2:00:02:11 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:02:11 PC1 PC Path_Length: 155
2014/5/2:00:02:11 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI8DD2.tmp
2014/5/2:00:02:11 PC1 PC Launch
2014/5/2:00:02:12 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI8DD2.tmp\Setup\AcSetup.dll
2014/5/2:00:02:12 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/2:00:02:14 PC1 PC PageOpen LaunchDialog
2014/5/2:00:02:15 PC1 PC PageOpen LicenseDialog
2014/5/2:00:02:17 PC1 PC PageOpen ProductInfoDialog
2014/5/2:00:02:44 PC1 PC PageOpen ProductSelectionDialog2
2014/5/2:00:03:16 PC1 PC PageOpen FullProgressDialog
2014/5/2:00:03:16 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "K:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/5/2:00:03:18 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/5/2:00:03:19 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "K:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/2:00:03:51 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/2:00:03:52 PC1 PC PageOpen InstallCompleteDialog
2014/5/2:00:04:35 PC1 PC === Setup ended ===
2014/5/2:00:05:14 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:05:14 PC1 PC Path_Length: 155
2014/5/2:00:05:14 PC1 PC Current Directory D:\autocad
2014/5/2:00:05:14 PC1 PC Launch
2014/5/2:00:05:14 PC1 PC CommandLine
2014/5/2:00:05:14 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI6155.tmp
2014/5/2:00:05:19 PC1 PC === Setup ended ===
2014/5/2:00:05:17 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:05:17 PC1 PC Path_Length: 155
2014/5/2:00:05:17 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI6155.tmp
2014/5/2:00:05:17 PC1 PC Launch
2014/5/2:00:05:17 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI6155.tmp\Setup\AcSetup.dll
2014/5/2:00:05:17 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/2:00:05:19 PC1 PC PageOpen LaunchDialog
2014/5/2:00:05:22 PC1 PC PageOpen LicenseDialog
2014/5/2:00:05:22 PC1 PC PageOpen ProductSelectionDialog2
2014/5/2:00:05:38 PC1 PC PageOpen FullProgressDialog
2014/5/2:00:05:38 PC1 PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="D:\autocad\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/2:00:05:39 PC1 PC Install Network License Manager Succeeded
2014/5/2:00:05:39 PC1 PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "D:\autocad\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\PC1\AppData\Local\Temp\vcredist_x86_2010.log
2014/5/2:00:05:47 PC1 PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/5/2:00:05:47 PC1 PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "D:\autocad\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\PC1\AppData\Local\Temp\vcredist_x64_2010.log
2014/5/2:00:05:53 PC1 PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/5/2:00:05:53 PC1 PC Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),;;;" ADSK_SOURCE_ROOT="D:\autocad\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/2:00:05:54 PC1 PC Install Autodesk CAD Manager Tools Succeeded
2014/5/2:00:05:54 PC1 PC Installing Autodesk Content Service: TRANSFORMS="D:\autocad\x64\en-us\Tools\snap\ContentService.mst;C:\Users\PC1\AppData\Local\Temp\_AI6155.tmp\x64\Tools\snap\ContentService-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\autocad\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/2:00:06:01 PC1 PC Install Autodesk Content Service Succeeded
2014/5/2:00:06:02 PC1 PC Installing Autodesk Content Service Language Pack: TRANSFORMS="C:\Users\PC1\AppData\Local\Temp\_AI6155.tmp\_la161F.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="D:\autocad\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/5/2:00:06:03 PC1 PC Install Autodesk Content Service Language Pack Succeeded
2014/5/2:00:06:03 PC1 PC PageOpen InstallCompleteDialog
2014/5/2:00:06:07 PC1 PC === Setup ended ===
2014/5/2:00:09:29 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:09:29 PC1 PC Path_Length: 155
2014/5/2:00:09:29 PC1 PC Current Directory D:\autocad
2014/5/2:00:09:29 PC1 PC Launch
2014/5/2:00:09:29 PC1 PC CommandLine
2014/5/2:00:09:29 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI4406.tmp
2014/5/2:00:09:32 PC1 PC === Setup ended ===
2014/5/2:00:09:31 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:09:31 PC1 PC Path_Length: 155
2014/5/2:00:09:31 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI4406.tmp
2014/5/2:00:09:31 PC1 PC Launch
2014/5/2:00:09:31 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI4406.tmp\Setup\AcSetup.dll
2014/5/2:00:09:31 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/2:00:09:32 PC1 PC PageOpen LaunchDialog
2014/5/2:00:09:34 PC1 PC PageOpen LicenseDialog
2014/5/2:00:09:36 PC1 PC PageOpen ProductInfoDialog
2014/5/2:00:09:42 PC1 PC PageOpen ProductSelectionDialog2
2014/5/2:00:09:44 PC1 PC PageOpen FullProgressDialog
2014/5/2:00:09:44 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\autocad\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/2:00:10:16 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/2:00:10:17 PC1 PC PageOpen InstallCompleteDialog
2014/5/2:00:12:00 PC1 PC === Setup ended ===
2014/5/2:00:12:19 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:12:19 PC1 PC Path_Length: 155
2014/5/2:00:12:19 PC1 PC Current Directory D:\autocad
2014/5/2:00:12:19 PC1 PC Launch
2014/5/2:00:12:19 PC1 PC CommandLine
2014/5/2:00:12:19 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIDBA8.tmp
2014/5/2:00:12:22 PC1 PC === Setup ended ===
2014/5/2:00:12:21 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:12:21 PC1 PC Path_Length: 155
2014/5/2:00:12:21 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AIDBA8.tmp
2014/5/2:00:12:21 PC1 PC Launch
2014/5/2:00:12:21 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AIDBA8.tmp\Setup\AcSetup.dll
2014/5/2:00:12:21 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/2:00:12:22 PC1 PC PageOpen LaunchDialog
2014/5/2:00:12:23 PC1 PC PageOpen LicenseDialog
2014/5/2:00:12:25 PC1 PC PageOpen ProductInfoDialog
2014/5/2:00:12:44 PC1 PC PageOpen ProductSelectionDialog2
2014/5/2:00:12:45 PC1 PC PageOpen FullProgressDialog
2014/5/2:00:12:45 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "D:\autocad\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/5/2:00:12:48 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/5/2:00:12:48 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\autocad\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/2:00:13:20 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/2:00:13:21 PC1 PC PageOpen InstallCompleteDialog
2014/5/2:00:23:35 PC1 PC === Setup ended ===
2014/5/2:00:23:40 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:23:40 PC1 PC Path_Length: 155
2014/5/2:00:23:40 PC1 PC Current Directory D:\autocad
2014/5/2:00:23:40 PC1 PC Launch
2014/5/2:00:23:40 PC1 PC CommandLine
2014/5/2:00:23:40 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI4241.tmp
2014/5/2:00:23:44 PC1 PC === Setup ended ===
2014/5/2:00:23:42 PC1 PC === Setup started on PC by PC1 ===
2014/5/2:00:23:42 PC1 PC Path_Length: 155
2014/5/2:00:23:42 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI4241.tmp
2014/5/2:00:23:42 PC1 PC Launch
2014/5/2:00:23:43 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI4241.tmp\Setup\AcSetup.dll
2014/5/2:00:23:43 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/2:00:23:44 PC1 PC PageOpen LaunchDialog
2014/5/2:00:23:45 PC1 PC PageOpen LicenseDialog
2014/5/2:00:23:47 PC1 PC PageOpen ProductInfoDialog
2014/5/2:00:24:16 PC1 PC PageOpen ProductSelectionDialog2
2014/5/2:00:24:17 PC1 PC PageOpen FullProgressDialog
2014/5/2:00:24:17 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\autocad\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/2:00:24:49 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2014/5/2:00:24:50 PC1 PC PageOpen InstallCompleteDialog
2014/5/2:00:25:00 PC1 PC === Setup ended ===
2014/5/6:23:45:38 PC1 PC === Setup started on PC by PC1 ===
2014/5/6:23:45:38 PC1 PC Path_Length: 155
2014/5/6:23:45:38 PC1 PC Current Directory D:\autocad
2014/5/6:23:45:38 PC1 PC Launch
2014/5/6:23:45:38 PC1 PC CommandLine
2014/5/6:23:45:38 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AICE15.tmp
2014/5/6:23:45:44 PC1 PC === Setup ended ===
2014/5/6:23:45:40 PC1 PC === Setup started on PC by PC1 ===
2014/5/6:23:45:40 PC1 PC Path_Length: 155
2014/5/6:23:45:40 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AICE15.tmp
2014/5/6:23:45:40 PC1 PC Launch
2014/5/6:23:45:40 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AICE15.tmp\Setup\AcSetup.dll
2014/5/6:23:45:40 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/6:23:45:44 PC1 PC PageOpen LaunchDialog
2014/5/6:23:45:51 PC1 PC PageOpen LicenseDialog
2014/5/6:23:45:53 PC1 PC PageOpen ProductInfoDialog
2014/5/6:23:47:20 PC1 PC PageOpen LicenseDialog
2014/5/6:23:47:22 PC1 PC PageOpen ProductInfoDialog
2014/5/6:23:47:45 PC1 PC PageOpen LicenseDialog
2014/5/6:23:47:46 PC1 PC PageOpen LaunchDialog
2014/5/6:23:47:53 PC1 PC PageOpen ProductInfoDialog
2014/5/6:23:48:07 PC1 PC === Setup ended ===
2014/5/6:23:48:08 PC1 PC === Setup started on PC by PC1 ===
2014/5/6:23:48:08 PC1 PC Path_Length: 155
2014/5/6:23:48:08 PC1 PC Current Directory D:\autocad
2014/5/6:23:48:08 PC1 PC Launch
2014/5/6:23:48:08 PC1 PC CommandLine
2014/5/6:23:48:08 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI193D.tmp
2014/5/6:23:48:11 PC1 PC === Setup ended ===
2014/5/6:23:48:10 PC1 PC === Setup started on PC by PC1 ===
2014/5/6:23:48:10 PC1 PC Path_Length: 155
2014/5/6:23:48:10 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI193D.tmp
2014/5/6:23:48:10 PC1 PC Launch
2014/5/6:23:48:10 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI193D.tmp\Setup\AcSetup.dll
2014/5/6:23:48:10 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/6:23:48:11 PC1 PC PageOpen LaunchDialog
2014/5/6:23:48:12 PC1 PC PageOpen LicenseDialog
2014/5/6:23:48:14 PC1 PC PageOpen ProductInfoDialog
2014/5/6:23:48:42 PC1 PC PageOpen LicenseDialog
2014/5/6:23:48:43 PC1 PC PageOpen LaunchDialog
2014/5/6:23:48:46 PC1 PC PageOpen LicenseDialog
2014/5/6:23:48:46 PC1 PC PageOpen ProductSelectionDialog2
2014/5/6:23:48:55 PC1 PC PageOpen LicenseDialog
2014/5/6:23:48:55 PC1 PC PageOpen LaunchDialog
2014/5/6:23:48:57 PC1 PC PageOpen LicenseDialog
2014/5/6:23:48:58 PC1 PC PageOpen ProductInfoDialog
2014/5/6:23:49:08 PC1 PC PageOpen LicenseDialog
2014/5/6:23:49:31 PC1 PC PageOpen LaunchDialog
2014/5/6:23:49:35 PC1 PC === Setup ended ===
2014/5/6:23:50:24 PC1 PC === Setup started on PC by PC1 ===
2014/5/6:23:50:24 PC1 PC Path_Length: 155
2014/5/6:23:50:24 PC1 PC Current Directory D:\autocad
2014/5/6:23:50:24 PC1 PC Launch
2014/5/6:23:50:24 PC1 PC CommandLine
2014/5/6:23:50:24 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI2BE1.tmp
2014/5/6:23:50:28 PC1 PC === Setup ended ===
2014/5/6:23:50:25 PC1 PC === Setup started on PC by PC1 ===
2014/5/6:23:50:25 PC1 PC Path_Length: 155
2014/5/6:23:50:25 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI2BE1.tmp
2014/5/6:23:50:25 PC1 PC Launch
2014/5/6:23:50:26 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI2BE1.tmp\Setup\AcSetup.dll
2014/5/6:23:50:26 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/6:23:50:28 PC1 PC PageOpen LaunchDialog
2014/5/6:23:50:29 PC1 PC PageOpen LicenseDialog
2014/5/6:23:50:31 PC1 PC PageOpen ProductInfoDialog
2014/5/6:23:53:10 PC1 PC PageOpen LicenseDialog
2014/5/6:23:53:11 PC1 PC PageOpen LaunchDialog
2014/5/6:23:53:14 PC1 PC PageOpen LicenseDialog
2014/5/6:23:53:14 PC1 PC PageOpen ProductSelectionDialog2
2014/5/6:23:53:25 PC1 PC PageOpen LicenseDialog
2014/5/6:23:53:25 PC1 PC PageOpen LaunchDialog
2014/5/6:23:53:27 PC1 PC PageOpen BeginDeploymentDialog
2014/5/6:23:53:27 PC1 PC CBeginDeploymentDialog::OnInitDialog reads PATH_LENGTH: 155
2014/5/6:23:53:32 PC1 PC === Setup ended ===
2014/5/7:00:12:13 PC1 PC === Setup started on PC by PC1 ===
2014/5/7:00:12:13 PC1 PC Path_Length: 155
2014/5/7:00:12:13 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI7BF3.tmp
2014/5/7:00:12:13 PC1 PC Launch
2014/5/7:00:12:15 PC1 PC === Setup ended ===
2014/5/7:00:12:13 PC1 PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/5/7:00:12:13 PC1 PC CommandLine
2014/5/7:00:12:18 PC1 PC === Setup started on PC by PC1 ===
2014/5/7:00:12:18 PC1 PC Path_Length: 155
2014/5/7:00:12:18 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI8E13.tmp
2014/5/7:00:12:18 PC1 PC Launch
2014/5/7:00:12:51 PC1 PC === Setup ended ===
2014/5/7:00:12:17 PC1 PC === Setup started on PC by PC1 ===
2014/5/7:00:12:17 PC1 PC Path_Length: 155
2014/5/7:00:12:17 PC1 PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2014/5/7:00:12:17 PC1 PC Launch
2014/5/7:00:12:17 PC1 PC CommandLine
2014/5/7:00:12:17 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI8E13.tmp
2014/5/7:00:34:45 PC1 PC === Setup started on PC by PC1 ===
2014/5/7:00:34:45 PC1 PC Path_Length: 155
2014/5/7:00:34:45 PC1 PC Current Directory K:
2014/5/7:00:34:45 PC1 PC Launch
2014/5/7:00:34:45 PC1 PC CommandLine
2014/5/7:00:34:45 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI1D33.tmp
2014/5/7:00:34:56 PC1 PC === Setup ended ===
2014/5/7:00:34:50 PC1 PC === Setup started on PC by PC1 ===
2014/5/7:00:34:50 PC1 PC Path_Length: 155
2014/5/7:00:34:50 PC1 PC Current Directory C:\Users\PC1\AppData\Local\Temp\_AI1D33.tmp
2014/5/7:00:34:50 PC1 PC Launch
2014/5/7:00:34:50 PC1 PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\PC1\AppData\Local\Temp\_AI1D33.tmp\Setup\AcSetup.dll
2014/5/7:00:34:50 PC1 PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/5/7:00:34:56 PC1 PC PageOpen LaunchDialog
2014/5/7:00:34:57 PC1 PC PageOpen LicenseDialog
2014/5/7:00:34:59 PC1 PC PageOpen ProductInfoDialog
2014/5/7:00:35:16 PC1 PC PageOpen ProductSelectionDialog2
2014/5/7:00:35:35 PC1 PC PageOpen FullProgressDialog
2014/5/7:00:35:35 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "K:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/5/7:00:35:37 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/5/7:00:35:37 PC1 PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "K:\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/5/7:00:36:10 PC1 PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
