Cannot install inventor 2012
enabled virus scanner
Naam van besturingssysteem Microsoft Windows 7 Professional
Versie 6.1.7601 Service Pack 1 Build 7601
Andere beschrijving van besturingssysteem Niet beschikbaar
Leverancier van besturingssysteem Microsoft Corporation
Systeemnaam SABERTOOTH
Systeemfabrikant System manufacturer
Systeemmodel System Product Name
Systeemtype Op x64-gebaseerde PC
Processor Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz, 3201 MHz, 4 core('s), 8 logische processor(s)
BIOS-versie/datum American Megatrends Inc. 1101, 11/05/2011
SMBIOS-versie 2.5
Map met Windows C:\Windows
Systeemmap C:\Windows\system32
Opstartapparaat \Device\HarddiskVolume3
Landinstelling België
HAL (Hardware Abstraction Layer) Versie = "6.1.7601.17514"
Gebruikersnaam Sabertooth\Curd
Tijdzone Romance (standaardtijd)
Geïnstalleerd fysiek geheugen (RAM) 12,0 GB
Totaal fysiek geheugen 12,0 GB
Beschikbaar fysiek geheugen 9,95 GB
Totaal virtueel geheugen 24,0 GB
Beschikbaar virtueel geheugen 21,7 GB
Ruimte voor wisselbestand 12,0 GB
Wisselbestand C:\pagefile.sys
grtz from belgium.curd
Solved by TravisNave. Go to Solution.
You might already have a newer version of Microsoft Visual C++ 2010 Redistributable (x86) installed. Use the Control Panel > Programs and Features to remove this version. Reboot, then reinstall your Autodesk product. It should install the version supplied and continue the installation. If not, consider installing the Microsoft Visual C++ 2010 Redistributable (x86) directly from Microsoft.com.
The installation log file is attached with this mail which i got after incomplete installation of Autodesk Inventor12.
someone please try to solve my problem , i tried many time to install this software but got same message
installation complete.some products failed to install
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
