Installation & Licensing
New Member
Sdalziel5
Message 1 of 7 (1,815 Views)
installalation of MAYA 2014 windows 8.1
1815 Views, 6 Replies
12-25-2013 07:55 PM
Have tried several times to down load ??
New lap top with allsystem requirements.  Had no problems loading auto cad but can't get Maya to download.
013/12/26:14:46:57 SDalziel5 STUARTDALZIEL === Setup started on STUARTDALZIEL by SDalziel5 ===
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Path_Length: 151
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Current Directory C:\Autodesk\Autodesk_Maya_2014_wi_en-US
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Launch
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/Autodesk_Maya_2014_wi_en-US_Setup.exe" /SN 900-43822430 /PK 657F1 /student /akamai /auth authparam /sid SESSION_ID
2013/12/26:14:46:57 SDalziel5 STUARTDALZIEL Current Directory C:\Users\SDALZI~1\AppData\Local\Temp\_AIBE08.tmp
2013/12/26:14:47:00 SDalziel5 STUARTDALZIEL === Setup ended ===
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL === Setup started on STUARTDALZIEL by SDalziel5 ===
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL Path_Length: 151
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL Current Directory C:\Users\SDALZI~1\AppData\Local\Temp\_AIBE08.tmp
2013/12/26:14:46:58 SDalziel5 STUARTDALZIEL Launch
2013/12/26:14:47:00 SDalziel5 STUARTDALZIEL Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/SETUP_x...
2013/12/26:14:47:00 SDalziel5 STUARTDALZIEL PageOpen LaunchDialog
2013/12/26:14:47:09 SDalziel5 STUARTDALZIEL PageOpen LicenseDialog
2013/12/26:14:47:14 SDalziel5 STUARTDALZIEL PageOpen ProductInfoDialog
2013/12/26:14:47:14 SDalziel5 STUARTDALZIEL PageOpen ProductSelectionDialog2
2013/12/26:14:47:16 SDalziel5 STUARTDALZIEL PageOpen FullProgressDialog
2013/12/26:14:47:16 SDalziel5 STUARTDALZIEL Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/DIRECTX...
2013/12/26:14:47:16 SDalziel5 STUARTDALZIEL Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Maya 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/26:14:47:42 SDalziel5 STUARTDALZIEL Install DirectX® Runtime Succeeded
2013/12/26:14:47:42 SDalziel5 STUARTDALZIEL Download Play Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2013/12/26:14:53:20 SDalziel5 STUARTDALZIEL Download Aborted Maya http://trial2.autodesk.com/SWDLDNET3/2014/MAYA/WI/EDU/{D667ADAE-728C-49A4-9179-8793438E5881}/Maya_en...
2013/12/26:14:53:20 SDalziel5 STUARTDALZIEL Install Autodesk® Maya® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/12/26:14:53:20 SDalziel5 STUARTDALZIEL Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
TravisNave
Message 2 of 7 (1,786 Views)
Re: installalation of MAYA 2014 windows 8.1
12-26-2013 06:58 AM in reply to: Sdalziel5
The downloads lately have been problematic.  You might instead try downloading from the virtual agent.  Others who have had your identical problem have had success this way:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
Sdalziel5
Message 3 of 7 (1,770 Views)
Re: installation of MAYA 2014 windows 8.1
12-26-2013 09:33 PM in reply to: Sdalziel5
Thank you.  That worked perfectly.  I am so excited I can get started now using Maya.
Member
marvin_gaerlan21
Message 4 of 7 (1,710 Views)
12-30-2013 05:21 AM in reply to: TravisNave
I just tried this and it did not work for me.
Error
Setup.exe - Bad Image
C:Windows\System32\MSVCP100.dll is either not design to run on windows or it contains an error.
I can download the file no problem, but I can't seem to install it.
TravisNave
Message 5 of 7 (1,695 Views)
12-30-2013 12:25 PM in reply to: marvin_gaerlan21
Error
You might edit the setup.ini to remove the check for Visual C++.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Member
marvin_gaerlan21
Message 6 of 7 (1,692 Views)
12-30-2013 12:33 PM in reply to: Sdalziel5
Do I have to download http://www.microsoft.com/en-us/download/details.aspx?id=3324 to follow this steps?
TravisNave
Message 7 of 7 (1,689 Views)
12-30-2013 12:36 PM in reply to: marvin_gaerlan21
Unlikely.  Just modify the setup.ini to remove the prerequisite or to ignore it.  Here's another resource of mine to explain it:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
