Installation & Licensing
install help!! cant locate Composite_2013.msi"...
2 REPLIES 2
1088 Views, 2 Replies
am just gonna ask if what is the problem of this.. i run the install setup of 3d max design 2013 on a 32 bit win7 OS and i cant proceed because it is looking for the "Composite 2013.msi"  but my C drive dont have a "Program Files (x86)" this is the message i got "cant locate program File(x86)/Composite/Composite_2013.msi"
... hope i choose the right 3d max,  for making a interactive 3d map of a building with a first person as a navigation.....
thanks,,,
2 REPLIES 2
TravisNave
Is this a deployment?  Or are you trying to install a 64-bit app on a 32-bit system?  Seems odd that it would look for a 32-bit Program Files equivelent when you're already on a 32-bit machine.  Provide some more information to help shed the light on this.
Autodesk Forums:
david.lau
in reply to: TravisNave
Can you try to redownload the software from the Virtual Agent (#3) from here:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
David Lau
Administrator Productivity
