Installation & Licensing
install and active an autodesk product with network license on single computer ?
4 REPLIES 4
391 Views, 4 Replies
I have a 3ds max creation suite, with a network license, and i work for a company with wireless network (my computer is not a host computer) . How can i active this product on my computer?
4 REPLIES 4
TravisNave
You do not activate a network license.  You need to install the software as a network version and point to the license manager on your network.
Autodesk Forums:
in reply to: TravisNave
The license manager was installed in my computer. I followed the guide to use license for network. But final i can't use the solfware.
TravisNave
Did you install the software as a network version?  Is it asking for activation or asking to point to the license server system?  If it is asking for activation codes, you need to reinstall as a network version.  If it is asking you to specify the license server, then you probably have a simply IPv6 issue.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
Thanks so much!
Administrator Productivity
