Installation & Licensing
install AutoCAD 2009 on new computer
4 REPLIES 4
jbbhofacre
1821 Views, 4 Replies
I own a copy of AutoCAD 2009 with a non expiring license. I have the serial & the Product Key says N/A. I will start work in an architect's office (for a few years I hope) and we tried to install my copy on their computer (they operate on Windows XP). We got it on the computer and it tryed to activate by getting (I believe it called) an activation code automatically on line... but couldn't connect. When I sent a request for help to Autodesk online I recieved this response
"response:
I see that you need assistance with a product that is 2009 or older.
Technical Support:
Autodesk no longer supports products that are 2009 or older. "
Is there a way to get my program to work on this new computer? Thanks.
4 REPLIES 4
HI,
try the license tansfer utility instead, so you can export the license from your previous system to a file and then import the license on the new installation from that file.
Be careful, when starting the license manager to export the license you have to know the id of the destination workstation. So start on the new system the transfer utility, write down the id the dialog provides and use that id when exporting the license!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
pendean
in reply to: jbbhofacre
Installation forum is at http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24 and they can usually help.
Charles_Shade
Not knowing for sure and you stated the Product key was N/A but I looked in the AutoCAD Knowledge base for Product keys.
2010: 001B1
2011: 001C1
2012: 001D1
2013: 001E1
2014: 001F1
Maybe 2009 is 001A1?
Support Offering: (click the tabs for options)
http://usa.autodesk.com/support-offerings/basic/
Licensing and license tranfer tips and help are at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18221949&linkID=9240617
Autodesk support is now on Twitter 24/5 (@autodeskhelp): https://twitter.com/AutodeskHelp
With a blog: http://blog.autodeskhelp.com/
Up & Ready Installation and Startup Help (free for new installs):
http://usa.autodesk.com/support-offerings/up-and-ready/
Safety Net / Per Incident Autodesk support (not free):
http://usa.autodesk.com/support-offerings/per-incident/
If you are on subscription, visit your Autodesk Subscription Page for direct Autodesk Help:
http://www.autodesk.com/subscriptionlogin
Contact a Reseller for support (not free):
http://www.autodesk.com/reseller
Customer Error Reporting:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=7047344&linkID=9240617
TravisNave
in reply to: Charles_Shade
Charles is right.  The product key is 001A1 and so long as you never upgraded it past 2009 either manually or under Subscription, then it should still activate.  You may need to send in your activation code to get a manual activation.
Autodesk Forums:
Administrator Productivity
