• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    how to obtain server codes for just some seats of total?
    79 Views, 6 Replies
    02-05-2013 09:36 AM
    I went to pull server codes using the web page, and the dumb thing gave me codes for all my seats.
    I only need codes for 2 seats.
    Can I do this online, or do I have to email adesk?
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: how to obtain server codes for just some seats of total?
    02-05-2013 09:45 AM in reply to: jmaeding
    i don't know what you mean by server codes
    do you mean feature codes?
    Serial number?
    02-05-2013 10:29 AM in reply to: DarrenP
    you must not be familiar with flexlm license servers.
    The typical process for network autodesk products is buy the product,
    install flexlm on a server,
    obtain codes and put in a license.lic file,
    point the flexlm server to that file, using the "services" option for us at least.
    So when you have two offices, and want to redistribute seats available on each server, you pull new codes.
    You must not exceed your total pool, or you are a pirate,
    So this thing where it pulls codes for all seats without asking is lame, makes it look like I am overusing network seats.
    *Expert Elite*
    TravisNave
    02-05-2013 11:54 AM in reply to: jmaeding
    Darren is an expert at FlexLM, he just wanted the clarification that you provided.
    You need to contact Autodesk and have them created a Distributed server for you.  You should have been able to create your own at http://register.autodesk.com.  I know I can.  It will allow you to split seats.
    If you cannot or wish to have it done, let Autodesk Activations do this.
    Please call Autodesk Product Registration and Authorization or your Reseller:
    http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    02-05-2013 12:07 PM in reply to: TravisNave
    That link is where I went and did not see the option for seat count. Seems like I have seen it before though.
    I know I can go through adesk or reseller, just wanted to know the online way.
    *Expert Elite*
    DarrenP
    02-05-2013 12:09 PM in reply to: jmaeding
    i also go this way: http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
    this creates a case no thats emailed to you
    when you call the activations number or use the chat window on that link you give them the case no with all the info in it
    02-05-2013 01:02 PM in reply to: DarrenP
    now that's more like a reply from an Expert Elite!
    I apparently do not make the cut so have to tease when I can :smileyhappy:
