Installation & Licensing
hostname using dns alias?
7 REPLIES 7
Message 1 of 8
andyfriday
1598 Views, 7 Replies
Does anyone know if I can use a DNS cname as the hostname in a flexlm licence file?
I'm thinking if the server dies we could moved the NIC into a second server so the host id is the same and just change where the cname points.
What do you think?
Cheers, Andy.
7 REPLIES 7
Message 2 of 8
in reply to: andyfriday
You can use the full DNS name.
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
http://jtbworld.blogspot.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2008
http://www.jtbworld.com/autocad2008.htm
"andyfriday" wrote in message news:5673193@discussion.autodesk.com...
licence file?
What do you think?
Cheers, Andy.
Message 3 of 8
andyfriday
I know realservername.domain.com would work.
I'm wondering whether a service alias cname such as flexlm.domain.com initially pointing to realserver.domain.com but able to be redirected would work.
So you could move the NIC to a new machine called realservername2.domain.com, update the cname to point to realserver2.domain.com and it would work.
cheers
Message 4 of 8
andyfriday
One final clarification. 🙂
So the host in the flexlm licence file would not change as it would be the cname flexlm.domain.com.
The host ID would not change as the NIC would be moved to the new server.
Message 5 of 8
I don't know for sure. I have not tried that.
Jimmy Bergmark
Owner/Developer
AutoCAD 2008
"andyfriday" wrote in message news:5673483@discussion.autodesk.com...
Message 6 of 8
> licence file?
> What do you think?
This will work out.
In some cases you can also replace the hostname with the special keyword:
"this_host". Then you won't need to change it when moving it to a new
machine.
Best Regards,
Henrik Goldman
Track your flexlm licenses and reduce your costs -
http://www.x-formation.com/license_statistics/index.html
Our licensing and software security blog -
http://blog.x-formation.com/
Protect your software - http://www.x-formation.com/LM-X
Message 7 of 8
Use a virtual Serrver, you can set the NIC.
licence file?
What do you think?
Cheers, Andy.
Message 8 of 8
> licence file?
I think this should work out. Essentially a
requirement is that it should be resolvable.
> I'm thinking if the
> so the host id
> What do you
think?
The only way to find out is to really try it. Some
times you can be surprised about what might come up.
Administrator Productivity
