Installation & Licensing
help installing auto cad LT 2005 to windows 7
2 REPLIES 2
1645 Views, 2 Replies
hi
can we install autocad LT 2005 in windows 7??
2 REPLIES 2
pendean
It's not a supported OS.
If you are using Win7 64bit Pro or higher, explore the 'XP compatibility mode' option to try and install old software like LT2005, it usually works but not a guarantee. Realize that Lt2005 updates may not install at all.
If you are using Win7 32bit, it should install with no issues: perhaps you can downgrade if the above tip does not work for you.
There are also some third party options outside of Microsoft and Autodesk if you want to take a chance: something called LongBow I believe, search for it on the internet.
TravisNave
in reply to: pendean
Dean is right.  Your other option is to install Windows XP Mode and install 2005 on it.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
