2011/12/14:09:04:44 yvo YVON === Setup started on YVON by yvo ===
2011/12/14:09:04:44 yvo YVON Launch
2011/12/14:09:05:37 yvo YVON === Setup ended ===
2011/12/14:09:05:38 yvo YVON PageOpen LaunchDialog
2011/12/14:09:06:43 yvo YVON PageOpen LicenseDialog
2011/12/14:09:06:47 yvo YVON PageOpen ProductInfoDialog
2011/12/14:09:06:52 yvo YVON PageOpen ProductSelectionDialog2
2011/12/14:09:06:58 yvo YVON PageOpen FullProgressDialog
2011/12/14:09:06:58 yvo YVON Installing DirectX Runtime: D:\tools\cad\3rdParty\DirectX\DXSETUP.exe /silent
2011/12/14:09:07:51 yvo YVON Install DirectX Runtime Succeeded
2011/12/14:09:07:51 yvo YVON Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\tools\cad\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/12/14:09:08:10 yvo YVON Install FaroSDK Succeeded
2011/12/14:09:08:10 yvo YVON Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\tools\cad\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/12/14:09:09:19 yvo YVON Install Autodesk Material Library 2012 Succeeded
2011/12/14:09:09:19 yvo YVON Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\tools\cad\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/12/14:09:10:26 yvo YVON Install Autodesk Material Library 2012 - Low Resolution Succeeded
2011/12/14:09:10:26 yvo YVON Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\tools\cad\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/12/14:09:10:52 yvo YVON Install Autodesk Content Service Succeeded
2011/12/14:09:10:54 yvo YVON Installing AutoCAD® Architecture 2012: TRANSFORMS="D:\tools\cad\x86\en-us\ACA\ACA.mst;C:\DOCUME~1\yvo\LOCALS~1\Temp\_AI8.tmp\x86\ACA\ACA-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\tools\cad\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD Architecture 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/12/14:09:11:06 yvo YVON Install AutoCAD® Architecture 2012 Failed Installation aborted, Result=1603
2011/12/14:09:11:24 yvo YVON Rollback Autodesk Content Service Succeeded
2011/12/14:09:12:32 yvo YVON Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2011/12/14:09:14:09 yvo YVON Rollback Autodesk Material Library 2012 Succeeded
2011/12/14:09:14:11 yvo YVON Rollback FaroSDK Succeeded
2011/12/14:09:14:12 yvo YVON Rollback DirectX Runtime Failed Failure is ignored, Result=1619
