My NLS AutoCAD Architecture 2009 64 went bonkers and locked up. I could not repair or reinstall from the control panel (it locked then too) so I removed it manually, cleaning out files and registry. takin this seriously and following advice in the Autodesk support document, I in fact I removed 16 Autodesk applications (the other 15 I could remove the "propper" way) and clean the drive and registry.
Now I can not reinstall the AutoCAD Architecture 2009 64 as it says it is already there, which it is not.
I must have missed a key in the registry.
So I either need a pointer to the key that indicates the software to be installed OR a switch to force the installer to install from the image regardless of software present or not (I seem to recall such a possibility).
Please help!
Please delete any reference to Autocad Archi. 2009 from the following registry hives. please back up(restore point) before you make any changes to the registry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData
HKEY_CLASSES_ROOT\Installer
