• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    fatal error Unhandled Access violation Reading 0xfffffff Exception at e78c0004h
    1565 Views, 4 Replies
    01-22-2013 06:19 PM
    I recently installed AutoCAD 2013 onto my computer which has windows 7 64 bit operating system. After completing installation, I tried to open AutoCAD and immediatly I recieved this error, "Fatal error: Unhandled Access violation Reading 0xffffffff Exception at e78c0004h. I was wondering if anybody knows what that error is signaling and could help me resolve the problem. Thank you!
    Please use plain text.
    TravisNave
    Re: fatal error Unhandled Access violation Reading 0xfffffff Exception at e78c00
    01-24-2013 08:16 AM in reply to: evan.g.mcmahon
    Make sure you have local admin rights and a certified video driver.  You should also test in another local administrator login to eliminate a profile issue.  If all of those still fail, you might have to reinstall your .NET Framework.
    .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
    http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    01-25-2013 01:08 PM in reply to: TravisNave
    The problem was my video card. I have a gtx 660m with optimus and I was getting the error on my dedicated card. I went into my nvidia preferences told it to run autocad using my integrated intel 4000 video card which did the trick. Thank you for all the help, much appreciated!
    Thanks!
    TravisNave
    01-25-2013 01:21 PM in reply to: evan.g.mcmahon
    Thanks for following up.  Hopefully it will help the next person!
    Travis Nave
    New Member
    05-05-2013 03:52 AM in reply to: evan.g.mcmahon
    I have the same problem with a new Dell laptop Inspiron 17, running Win 7 Enterprise, having Intel 4000 and ATI Radeon 7600 video cards (why 2?). How do I disable this feature in Radeon? I updated the drivers but didn't find this option.
