Installation & Licensing
deniedyou
Message 1 of 23 (890 Views)
failed to install....
890 Views, 22 Replies
01-09-2013 09:46 PM
whats up with this garbage installation method you guys have.....
I cant install this.
I tried 100x with install , 300x with browser download ...
Setupid initiliazation failed....  error downloading please try autodesk again...
and with the browser download it stops downloading and gives error....
Check ur file its 1.1 gb with browser download when it says 3.3 gb... Corrupted file.
I have FIREWALL etc.. turned off so dont treat me like a noob ... fix the program plz thx
deniedyou
Message 2 of 23 (882 Views)
Re: failed to install....
01-09-2013 09:59 PM in reply to: deniedyou
2013/1/10:00:05:49 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:05:49 Farshad FARSHAD-PC Launch
2013/1/10:00:05:49 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:06:45 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:05:50 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:05:50 Farshad FARSHAD-PC Launch
2013/1/10:00:06:33 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:06:34 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:06:35 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:06:35 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:06:45 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:19:37 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:19:37 Farshad FARSHAD-PC Launch
2013/1/10:00:19:37 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:19:55 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:19:38 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:19:38 Farshad FARSHAD-PC Launch
2013/1/10:00:19:45 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:19:49 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:19:50 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:19:50 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:20:11 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:20:19 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:20:19 Farshad FARSHAD-PC Launch
2013/1/10:00:20:19 Farshad FARSHAD-PC CommandLine
2013/1/10:00:20:24 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:20:21 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:20:21 Farshad FARSHAD-PC Launch
2013/1/10:00:20:25 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:21:44 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:21:44 Farshad FARSHAD-PC Launch
2013/1/10:00:21:44 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:23:18 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:21:46 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:21:46 Farshad FARSHAD-PC Launch
2013/1/10:00:21:53 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:22:09 Farshad FARSHAD-PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:22:30 Farshad FARSHAD-PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:23:10 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:23:10 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:23:10 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:23:19 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:27:43 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:27:43 Farshad FARSHAD-PC Launch
2013/1/10:00:27:43 Farshad FARSHAD-PC CommandLine
2013/1/10:00:27:47 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:27:44 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:27:44 Farshad FARSHAD-PC Launch
2013/1/10:00:27:48 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:31:04 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:31:04 Farshad FARSHAD-PC Launch
2013/1/10:00:31:04 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:32:13 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:31:05 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:31:05 Farshad FARSHAD-PC Launch
2013/1/10:00:31:11 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:31:14 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:31:15 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:31:15 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:32:14 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:32:31 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:32:31 Farshad FARSHAD-PC Launch
2013/1/10:00:32:34 Farshad FARSHAD-PC [Error: 1056] An instance of the service is already running.
2013/1/10:00:32:34 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:32:30 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:32:30 Farshad FARSHAD-PC Launch
2013/1/10:00:32:30 Farshad FARSHAD-PC CommandLine
2013/1/10:00:32:35 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:41:33 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:41:33 Farshad FARSHAD-PC Launch
2013/1/10:00:41:42 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:41:45 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:41:45 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:41:45 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:49:42 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:41:30 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:41:30 Farshad FARSHAD-PC Launch
2013/1/10:00:41:30 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:53:56 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:53:56 Farshad FARSHAD-PC Launch
2013/1/10:00:53:56 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:54:22 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:53:59 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:53:59 Farshad FARSHAD-PC Launch
2013/1/10:00:54:10 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:54:21 Farshad FARSHAD-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:54:22 Farshad FARSHAD-PC PageOpen LaunchDialog
2013/1/10:00:54:41 Farshad FARSHAD-PC PageOpen LicenseDialog
2013/1/10:00:54:41 Farshad FARSHAD-PC PageOpen ProductInfoDialog
2013/1/10:00:54:41 Farshad FARSHAD-PC PageOpen ProductSelectionDialog2
2013/1/10:00:55:41 Farshad FARSHAD-PC PageOpen FullProgressDialog
2013/1/10:00:55:41 Farshad FARSHAD-PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:00:55:43 Farshad FARSHAD-PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:00:55:43 Farshad FARSHAD-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:00:56:18 Farshad FARSHAD-PC Install DirectX Runtime Succeeded
2013/1/10:00:56:19 Farshad FARSHAD-PC Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:00:56:21 Farshad FARSHAD-PC Download Error CM2013 Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:00:56:26 Farshad FARSHAD-PC Download Aborted CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:00:56:26 Farshad FARSHAD-PC Install Autodesk Material Library 2013 Failed Download Failed, Installation aborted, Result=1603
2013/1/10:00:56:26 Farshad FARSHAD-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
camilo.lemos
Message 3 of 23 (849 Views)
01-10-2013 12:42 AM in reply to: deniedyou
Hi deniedyou,
Sorry to hear you're having problems with your downlod and installation of AutoCAD 2013.
Just a clarification before we tackle your issue:
The file size discrepancy is due to different compression methods being used for dfferent download methods, I've just tested all 3 download methods and the files do not seem to be corrupted, so I would suggest you double check your firewall and anti-virus settings.
I'm posting below two direct download links, which I've also just tested too. These links are temporary and will expire in 72 hours, so please make sure you use them ASAP:
AutoCAD 2013 32-bits
AutoCAD 2013 64-bits
The bottom two lines of your logs mention error 1603. In case you get those during an installation again, this thread will help you work around that error.
Let me know if you need any further assistance.
Camilo Lemos
deniedyou
Message 4 of 23 (819 Views)
01-10-2013 09:28 AM in reply to: camilo.lemos
CRC failed in 3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1049.exe
Unexpected end of archive
i uninstalled netframework 4.0 and C++ and rebooted... but still same..
*Expert Elite*
TravisNave
Message 5 of 23 (812 Views)
01-10-2013 09:47 AM in reply to: deniedyou
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
deniedyou
Message 6 of 23 (809 Views)
01-10-2013 09:51 AM in reply to: TravisNave
lol thats irrelevant... what does browser have to do anything with me installing this program on computer... makes no sense
i already try to unzip and i get this error ^^^^ i posted above.
*Expert Elite*
TravisNave
Message 7 of 23 (803 Views)
01-10-2013 09:56 AM in reply to: deniedyou
Because it is a known issue, that's why it is posted in multiple support forums. Just trying to help.
Discussion Forum Ground Rules
deniedyou
Message 8 of 23 (800 Views)
01-10-2013 09:59 AM in reply to: TravisNave
so download the same link with a different browser?
*Expert Elite*
TravisNave
Message 9 of 23 (798 Views)
01-10-2013 10:00 AM in reply to: deniedyou
Yeah basically.  I don't know why some browsers have download issues with these compressed files, but they do.  I share your frustration.
deniedyou
Message 10 of 23 (791 Views)
01-10-2013 10:04 AM in reply to: TravisNave
what i dont get is why is this program so hard to deal with and why is there so much error and bugs....
Why cant there be  a simple install or download link instead of a ZIP COMPRESSED FILE...
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
