whats up with this garbage installation method you guys have.....
I cant install this.
I tried 100x with install , 300x with browser download ...
Setupid initiliazation failed.... error downloading please try autodesk again...
and with the browser download it stops downloading and gives error....
Check ur file its 1.1 gb with browser download when it says 3.3 gb... Corrupted file.
I have FIREWALL etc.. turned off so dont treat me like a noob ... fix the program plz thx
2013/1/10:00:05:49 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:05:49 Farshad FARSHAD-PC Launch
2013/1/10:00:05:49 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:06:45 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:05:50 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:05:50 Farshad FARSHAD-PC Launch
2013/1/10:00:06:33 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:06:34 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:06:35 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:06:35 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:06:45 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:19:37 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:19:37 Farshad FARSHAD-PC Launch
2013/1/10:00:19:37 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:19:55 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:19:38 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:19:38 Farshad FARSHAD-PC Launch
2013/1/10:00:19:45 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:19:49 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:19:50 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:19:50 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:20:11 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:20:19 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:20:19 Farshad FARSHAD-PC Launch
2013/1/10:00:20:19 Farshad FARSHAD-PC CommandLine
2013/1/10:00:20:24 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:20:21 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:20:21 Farshad FARSHAD-PC Launch
2013/1/10:00:20:25 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:21:44 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:21:44 Farshad FARSHAD-PC Launch
2013/1/10:00:21:44 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:23:18 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:21:46 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:21:46 Farshad FARSHAD-PC Launch
2013/1/10:00:21:53 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:22:09 Farshad FARSHAD-PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:22:30 Farshad FARSHAD-PC Download Error SETUP_CONFIG <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:23:10 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:23:10 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:23:10 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:23:19 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:27:43 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:27:43 Farshad FARSHAD-PC Launch
2013/1/10:00:27:43 Farshad FARSHAD-PC CommandLine
2013/1/10:00:27:47 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:27:44 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:27:44 Farshad FARSHAD-PC Launch
2013/1/10:00:27:48 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:31:04 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:31:04 Farshad FARSHAD-PC Launch
2013/1/10:00:31:04 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:32:13 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:31:05 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:31:05 Farshad FARSHAD-PC Launch
2013/1/10:00:31:11 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:31:14 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:31:15 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:31:15 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:32:14 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:32:31 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:32:31 Farshad FARSHAD-PC Launch
2013/1/10:00:32:34 Farshad FARSHAD-PC [Error: 1056] An instance of the service is already running.
2013/1/10:00:32:34 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:32:30 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:32:30 Farshad FARSHAD-PC Launch
2013/1/10:00:32:30 Farshad FARSHAD-PC CommandLine
2013/1/10:00:32:35 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:41:33 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:41:33 Farshad FARSHAD-PC Launch
2013/1/10:00:41:42 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:41:45 Farshad FARSHAD-PC Download Error SETUP_CONFIG Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:41:45 Farshad FARSHAD-PC Download Aborted SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:41:45 Farshad FARSHAD-PC Error downloading. Please Install Now again from the Autodesk website. 2013/1/10:00:49:42 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:41:30 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:41:30 Farshad FARSHAD-PC Launch
2013/1/10:00:41:30 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:53:56 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:53:56 Farshad FARSHAD-PC Launch
2013/1/10:00:53:56 Farshad FARSHAD-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-35909644 /PK 001E1 /student /skipEULA /akamai /auth /sid
2013/1/10:00:54:22 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:00:53:59 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:00:53:59 Farshad FARSHAD-PC Launch
2013/1/10:00:54:10 Farshad FARSHAD-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:54:21 Farshad FARSHAD-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET...
2013/1/10:00:54:22 Farshad FARSHAD-PC PageOpen LaunchDialog
2013/1/10:00:54:41 Farshad FARSHAD-PC PageOpen LicenseDialog
2013/1/10:00:54:41 Farshad FARSHAD-PC PageOpen ProductInfoDialog
2013/1/10:00:54:41 Farshad FARSHAD-PC PageOpen ProductSelectionDialog2
2013/1/10:00:55:41 Farshad FARSHAD-PC PageOpen FullProgressDialog
2013/1/10:00:55:41 Farshad FARSHAD-PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:00:55:43 Farshad FARSHAD-PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR...
2013/1/10:00:55:43 Farshad FARSHAD-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:00:56:18 Farshad FARSHAD-PC Install DirectX Runtime Succeeded
2013/1/10:00:56:19 Farshad FARSHAD-PC Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:00:56:21 Farshad FARSHAD-PC Download Error CM2013 Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:00:56:26 Farshad FARSHAD-PC Download Aborted CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/CM2...
2013/1/10:00:56:26 Farshad FARSHAD-PC Install Autodesk Material Library 2013 Failed Download Failed, Installation aborted, Result=1603
2013/1/10:00:56:26 Farshad FARSHAD-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Hi deniedyou,
Sorry to hear you're having problems with your downlod and installation of AutoCAD 2013.
Just a clarification before we tackle your issue:
The file size discrepancy is due to different compression methods being used for dfferent download methods, I've just tested all 3 download methods and the files do not seem to be corrupted, so I would suggest you double check your firewall and anti-virus settings.
I'm posting below two direct download links, which I've also just tested too. These links are temporary and will expire in 72 hours, so please make sure you use them ASAP:
The bottom two lines of your logs mention error 1603. In case you get those during an installation again, this thread will help you work around that error.
Let me know if you need any further assistance.
CRC failed in 3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1049.exe
Unexpected end of archive
i uninstalled netframework 4.0 and C++ and rebooted... but still same..
Problems downloading the Autodesk software and/or CRC errors may be avoided by using another web browser, or using the alternate browser download method.
For more detailed information on this process, please see the following blog post tip here:
http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
lol thats irrelevant... what does browser have to do anything with me installing this program on computer... makes no sense
i already try to unzip and i get this error ^^^^ i posted above.
Because it is a known issue, that's why it is posted in multiple support forums. Just trying to help.
Yeah basically. I don't know why some browsers have download issues with these compressed files, but they do. I share your frustration.
what i dont get is why is this program so hard to deal with and why is there so much error and bugs....
Why cant there be a simple install or download link instead of a ZIP COMPRESSED FILE...
Well the program is multiple gigs in download and that presents itself with a multitude of potential failures in delivery. Physical media is better, but it is what it is.
lol..... what a joke..
That actually was the problem.
I used google chrome to download , and it was the issue...
i just used internet explorer and re downloaded the CAD install and the installed went smooth to the end.....
Problem is solved thank you so much dude that was it.
Excellent. Glad you got it going. I know it's one of those weird things.
it failed again...
2013/1/10:13:11:33 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:13:11:33 Farshad FARSHAD-PC Launch
2013/1/10:13:11:41 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:13:11:36 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:13:11:36 Farshad FARSHAD-PC Launch
2013/1/10:13:11:41 Farshad FARSHAD-PC PageOpen LaunchDialog
2013/1/10:13:11:47 Farshad FARSHAD-PC PageOpen LicenseDialog
2013/1/10:13:11:55 Farshad FARSHAD-PC PageOpen ProductInfoDialog
2013/1/10:13:13:59 Farshad FARSHAD-PC PageOpen ProductSelectionDialog2
2013/1/10:13:14:17 Farshad FARSHAD-PC PageOpen FullProgressDialog
2013/1/10:13:14:17 Farshad FARSHAD-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/1/10:13:18:12 Farshad FARSHAD-PC Install .NET Framework Runtime 4.0 Succeeded
2013/1/10:13:18:12 Farshad FARSHAD-PC Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/1/10:13:22:22 Farshad FARSHAD-PC Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/1/10:13:22:22 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2013/1/10:13:22:37 Farshad FARSHAD-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2013/1/10:13:22:37 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe /q
2013/1/10:13:22:51 Farshad FARSHAD-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2013/1/10:13:22:51 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart /l C:\Users\Farshad\AppData\Local\Temp\vcredist_x86_2010.log
2013/1/10:13:23:00 Farshad FARSHAD-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/1/10:13:23:00 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart /l C:\Users\Farshad\AppData\Local\Temp\vcredist_x64_2010.log
2013/1/10:13:23:10 Farshad FARSHAD-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/1/10:13:23:10 Farshad FARSHAD-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:13:23:57 Farshad FARSHAD-PC Install DirectX Runtime Succeeded
2013/1/10:13:23:57 Farshad FARSHAD-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:24:21 Farshad FARSHAD-PC Install Autodesk Material Library 2013 Succeeded
2013/1/10:13:24:21 Farshad FARSHAD-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:24:38 Farshad FARSHAD-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:13:24:38 Farshad FARSHAD-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:24:57 Farshad FARSHAD-PC Install Autodesk Content Service Succeeded
2013/1/10:13:24:57 Farshad FARSHAD-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:25:03 Farshad FARSHAD-PC Install Autodesk Content Service Language Pack Succeeded
2013/1/10:13:25:03 Farshad FARSHAD-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Farshad\AppData\Local\Temp\_AIE724.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:28:49 Farshad FARSHAD-PC Install AutoCAD® 2013 Succeeded
2013/1/10:13:28:51 Farshad FARSHAD-PC Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\Farshad\AppData\Local\Temp\_AIE724.tmp\_laB687.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:29:32 Farshad FARSHAD-PC Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:13:29:32 Farshad FARSHAD-PC Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:29:49 Farshad FARSHAD-PC Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:13:29:49 Farshad FARSHAD-PC Installing Autodesk Cloud sync: ADLANGUAGE=en-us ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:29:55 Farshad FARSHAD-PC Install Autodesk Cloud sync Succeeded
2013/1/10:13:29:55 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Farshad\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:13:30:06 Farshad FARSHAD-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:13:30:06 Farshad FARSHAD-PC Rollback Autodesk Cloud sync Failed Failure is ignored, Result=1603
2013/1/10:13:30:12 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:13:30:18 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:13:30:49 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Succeeded
2013/1/10:13:30:54 Farshad FARSHAD-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:13:30:57 Farshad FARSHAD-PC Rollback Autodesk Content Service Succeeded
2013/1/10:13:31:09 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:13:31:27 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:13:31:27 Farshad FARSHAD-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:13:31:27 Farshad FARSHAD-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/1/10:13:31:27 Farshad FARSHAD-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2013/1/10:13:31:27 Farshad FARSHAD-PC Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2013/1/10:13:31:27 Farshad FARSHAD-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
This time you can blame Microsoft.
What you will want to do is go into your Control Panel and uninstall your MS Visual C++ 2005. Then run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
i did that now im getting another one....
2013/1/10:13:31:28 Farshad FARSHAD-PC PageOpen InstallCompleteDialog
2013/1/10:13:36:14 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:13:36:33 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:13:36:33 Farshad FARSHAD-PC Launch
2013/1/10:13:36:44 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:13:36:36 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:13:36:36 Farshad FARSHAD-PC Launch
2013/1/10:13:36:40 Farshad FARSHAD-PC PageOpen LaunchDialog
2013/1/10:13:36:48 Farshad FARSHAD-PC PageOpen LicenseDialog
2013/1/10:13:36:51 Farshad FARSHAD-PC PageOpen ProductInfoDialog
2013/1/10:13:36:59 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:13:48:58 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:13:48:58 Farshad FARSHAD-PC Launch
2013/1/10:13:49:10 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:13:49:00 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:13:49:00 Farshad FARSHAD-PC Launch
2013/1/10:13:49:11 Farshad FARSHAD-PC PageOpen LaunchDialog
2013/1/10:13:49:17 Farshad FARSHAD-PC PageOpen LicenseDialog
2013/1/10:13:49:19 Farshad FARSHAD-PC PageOpen ProductInfoDialog
2013/1/10:13:50:07 Farshad FARSHAD-PC PageOpen ProductSelectionDialog2
2013/1/10:13:50:25 Farshad FARSHAD-PC PageOpen FullProgressDialog
2013/1/10:13:50:25 Farshad FARSHAD-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:13:51:11 Farshad FARSHAD-PC Install DirectX Runtime Succeeded
2013/1/10:13:51:11 Farshad FARSHAD-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:51:31 Farshad FARSHAD-PC Install Autodesk Material Library 2013 Succeeded
2013/1/10:13:51:31 Farshad FARSHAD-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:51:48 Farshad FARSHAD-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:13:51:48 Farshad FARSHAD-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:52:04 Farshad FARSHAD-PC Install Autodesk Content Service Succeeded
2013/1/10:13:52:04 Farshad FARSHAD-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:52:12 Farshad FARSHAD-PC Install Autodesk Content Service Language Pack Succeeded
2013/1/10:13:52:12 Farshad FARSHAD-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Farshad\AppData\Local\Temp\_AI279D.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:55:51 Farshad FARSHAD-PC Install AutoCAD® 2013 Succeeded
2013/1/10:13:55:52 Farshad FARSHAD-PC Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\Farshad\AppData\Local\Temp\_AI279D.tmp\_la75F1.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:56:34 Farshad FARSHAD-PC Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:13:56:34 Farshad FARSHAD-PC Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:13:56:55 Farshad FARSHAD-PC Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:13:56:56 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Farshad\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:13:57:07 Farshad FARSHAD-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:13:57:13 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:13:57:21 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:13:57:55 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Succeeded
2013/1/10:13:57:59 Farshad FARSHAD-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:13:58:03 Farshad FARSHAD-PC Rollback Autodesk Content Service Succeeded
2013/1/10:13:58:16 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:13:58:35 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:13:58:35 Farshad FARSHAD-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/1/10:13:58:36 Farshad FARSHAD-PC PageOpen InstallCompleteDialog
2013/1/10:14:02:48 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:14:04:45 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:14:04:45 Farshad FARSHAD-PC Launch
2013/1/10:14:04:57 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:14:06:11 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:14:06:11 Farshad FARSHAD-PC Launch
2013/1/10:14:06:11 Farshad FARSHAD-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/10:14:06:13 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:14:04:47 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:14:04:47 Farshad FARSHAD-PC Launch
2013/1/10:14:04:53 Farshad FARSHAD-PC PageOpen LaunchDialog
2013/1/10:14:04:59 Farshad FARSHAD-PC PageOpen LicenseDialog
2013/1/10:14:05:03 Farshad FARSHAD-PC PageOpen ProductInfoDialog
2013/1/10:14:06:59 Farshad FARSHAD-PC PageOpen ProductSelectionDialog2
2013/1/10:14:07:20 Farshad FARSHAD-PC PageOpen FullProgressDialog
2013/1/10:14:07:20 Farshad FARSHAD-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:14:07:59 Farshad FARSHAD-PC Install DirectX Runtime Succeeded
2013/1/10:14:07:59 Farshad FARSHAD-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:08:27 Farshad FARSHAD-PC Install Autodesk Material Library 2013 Succeeded
2013/1/10:14:08:27 Farshad FARSHAD-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:08:46 Farshad FARSHAD-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:14:08:46 Farshad FARSHAD-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:09:01 Farshad FARSHAD-PC Install Autodesk Content Service Succeeded
2013/1/10:14:09:01 Farshad FARSHAD-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:09:09 Farshad FARSHAD-PC Install Autodesk Content Service Language Pack Succeeded
2013/1/10:14:09:09 Farshad FARSHAD-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Farshad\AppData\Local\Temp\_AI9BF2.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:12:58 Farshad FARSHAD-PC Install AutoCAD® 2013 Succeeded
2013/1/10:14:12:59 Farshad FARSHAD-PC Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\Farshad\AppData\Local\Temp\_AI9BF2.tmp\_la23CD.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:13:37 Farshad FARSHAD-PC Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:14:13:37 Farshad FARSHAD-PC Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:13:58 Farshad FARSHAD-PC Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:14:13:58 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Farshad\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:14:14:10 Farshad FARSHAD-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:14:14:18 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:14:14:25 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:14:14:58 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Succeeded
2013/1/10:14:15:01 Farshad FARSHAD-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:14:15:05 Farshad FARSHAD-PC Rollback Autodesk Content Service Succeeded
2013/1/10:14:15:17 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:14:15:35 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:14:15:35 Farshad FARSHAD-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Yeah, that prereq is hosed on your machine for some reason. Go see if you can install it manually from Microsoft.
http://www.microsoft.com/en-us/download/details.aspx?id=14431
i did same results....
2013/1/10:14:15:36 Farshad FARSHAD-PC PageOpen InstallCompleteDialog
2013/1/10:14:21:30 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:14:34:16 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:14:34:16 Farshad FARSHAD-PC Launch
2013/1/10:14:34:40 Farshad FARSHAD-PC === Setup ended ===
2013/1/10:14:34:17 Farshad FARSHAD-PC === Setup started on FARSHAD-PC by Farshad ===
2013/1/10:14:34:17 Farshad FARSHAD-PC Launch
2013/1/10:14:34:35 Farshad FARSHAD-PC PageOpen LaunchDialog
2013/1/10:14:35:00 Farshad FARSHAD-PC PageOpen LicenseDialog
2013/1/10:14:35:06 Farshad FARSHAD-PC PageOpen ProductInfoDialog
2013/1/10:14:35:26 Farshad FARSHAD-PC PageOpen ProductSelectionDialog2
2013/1/10:14:35:39 Farshad FARSHAD-PC PageOpen FullProgressDialog
2013/1/10:14:35:39 Farshad FARSHAD-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/10:14:36:17 Farshad FARSHAD-PC Install DirectX Runtime Succeeded
2013/1/10:14:36:17 Farshad FARSHAD-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:36:34 Farshad FARSHAD-PC Install Autodesk Material Library 2013 Succeeded
2013/1/10:14:36:34 Farshad FARSHAD-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:36:48 Farshad FARSHAD-PC Install Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:14:36:48 Farshad FARSHAD-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:36:58 Farshad FARSHAD-PC Install Autodesk Content Service Succeeded
2013/1/10:14:36:58 Farshad FARSHAD-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:37:10 Farshad FARSHAD-PC Install Autodesk Content Service Language Pack Succeeded
2013/1/10:14:37:11 Farshad FARSHAD-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\AutoCAD_2013_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Farshad\AppData\Local\Temp\_AIA2F5.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:39:51 Farshad FARSHAD-PC Install AutoCAD® 2013 Succeeded
2013/1/10:14:39:52 Farshad FARSHAD-PC Installing AutoCAD® 2013 Language Pack: TRANSFORMS="C:\Users\Farshad\AppData\Local\Temp\_AIA2F5.tmp\_laBE19.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:40:32 Farshad FARSHAD-PC Install AutoCAD® 2013 Language Pack Succeeded
2013/1/10:14:40:32 Farshad FARSHAD-PC Installing AutoCAD® 2013 Product Specific Pack: INSTALLSHORTCUTS=0 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/10:14:40:47 Farshad FARSHAD-PC Install AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:14:40:47 Farshad FARSHAD-PC Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Farshad\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/1/10:14:40:58 Farshad FARSHAD-PC Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2013/1/10:14:41:04 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Product Specific Pack Succeeded
2013/1/10:14:41:12 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Language Pack Succeeded
2013/1/10:14:41:42 Farshad FARSHAD-PC Rollback AutoCAD® 2013 Succeeded
2013/1/10:14:41:45 Farshad FARSHAD-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/1/10:14:41:48 Farshad FARSHAD-PC Rollback Autodesk Content Service Succeeded
2013/1/10:14:41:59 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 - Low Resolution Succeeded
2013/1/10:14:42:16 Farshad FARSHAD-PC Rollback Autodesk Material Library 2013 Succeeded
2013/1/10:14:42:16 Farshad FARSHAD-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
You're having all sorts of luck.
You might have the installer skip the check for this prereq in the setup.ini file. I have instructions on how to do this in my link further down here:
that thread does not really explain good...
whats the line that i must edit on setup.ini to skip it?
