I have installed Autodesk maya 2013 on my personal computer with the student license. I recently purchased another laptop and I am trying to instal Maya onto that too. I instaled Maya2014 on my laptop a couple of months ago and also used it a couple of times. I reopened the software yesterday on my laptop and Maya failed to open and kept crashing.
I uninstaled all Autodesk packages from the laptop and then decided to instal Maya fresh again.
However, each time I instal, the instalation fails. This happens for both 2013 and 2014.
Would appreicate any help in fixing this. I am also attaching the logfile info for the failed instalation of Maya as well a snapshot of the error.
I also got another error during the instalation process and I am not sure what it means. The instalation continued to progress even after encountering this error. Attached a snapshot of that too.
Sorry to hear that you're having problems installing Maya 2013/2014.
This error can indicates that the PIT Config file used to register the product with the PIT file at install time cannot be found or cannot be opened.
Info Pit file:
Is the PIT Config file in a folder that you have access to when the product is installed?
Or it is possible that the machine has an existing bad pit file that did not get removed while uninstalling.
Remove the corresponding data under “C:\ProgramData\Autodesk\Adlm" and re-attempt the installation.
Let us know if it helps.
Thanks for the response.
I do have access to the PIT file under the Adlm folder.
I made a copy of the files in that folder and then deleted it.
I am trying a fresh instalation again. i will let you know if this works
Vijay
Perfect...
deleting the .pit file did the trick.
I was able to instal maya once again.
Thanks for your help.
Vijay
So, I installed a fresh package of Maya2013 on my laptop. When I open Maya after installation, I get the autodesk Lincesing window and it remains in this window forever.
this happens for Maya Backburner, Composite etc.
I checked the CPU usage during this time and it doesnt seem to be hogging the CPU. So, i am not sure whats going wrong at this stage.
I removed Maya2014 earlier from my laptop because it was doing the same thing. Looks like the same problem exists for 2013 as well.
Any thoughts?
Hey guys i'm trying to install MAYA 2013 and i had it before, on my new laptop it is giving me installation issues. I tried most of the things on the forum except overriding the install with code because i dont know how to do that. Well, in the log I believe the issue is with my DirectX and it says failure, everytime i attempt. Any help, please? Email me at telfortsam@yahoo.com or reply. I need my MAYA
2014/7/17:19:21:43 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:19:21:43 Samnold SAMNOLD Launch
2014/7/17:19:21:43 Samnold SAMNOLD CommandLine /url "http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/Autodesk_Maya_2013_English_Japanese_SimplifiedChines... /SN 900-31520570 /PK 657E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/17:19:21:54 Samnold SAMNOLD === Setup ended ===
2014/7/17:19:21:48 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:19:21:48 Samnold SAMNOLD Launch
2014/7/17:19:21:50 Samnold SAMNOLD Download Skipped SETUP_CONFIG http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/SETUP_x64.tar...
2014/7/17:19:21:54 Samnold SAMNOLD PageOpen LaunchDialog
2014/7/17:19:28:13 Samnold SAMNOLD PageOpen LicenseDialog
2014/7/17:19:28:13 Samnold SAMNOLD PageOpen ProductInfoDialog
2014/7/17:19:28:13 Samnold SAMNOLD PageOpen ProductSelectionDialog2
2014/7/17:19:28:29 Samnold SAMNOLD PageOpen FullProgressDialog
2014/7/17:19:28:31 Samnold SAMNOLD Download Skipped DIRECTX http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/DIRECTX.tar.l...
2014/7/17:19:28:31 Samnold SAMNOLD Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Maya 2013\3rdParty\DirectX\DXSETUP.exe /silent
2014/7/17:19:31:11 Samnold SAMNOLD Install DirectX® Runtime Succeeded
2014/7/17:19:31:15 Samnold SAMNOLD Download Play Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:20:10:45 Samnold SAMNOLD Download Aborted Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:20:10:45 Samnold SAMNOLD Install Autodesk® Maya® 2013 Failed Download Failed, Installation aborted, Result=1603
2014/7/17:20:10:48 Samnold SAMNOLD Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/7/17:20:10:49 Samnold SAMNOLD PageOpen InstallCompleteDialog
2014/7/17:20:16:59 Samnold SAMNOLD === Setup ended ===
2014/7/17:20:21:04 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:20:21:04 Samnold SAMNOLD Launch
2014/7/17:20:21:04 Samnold SAMNOLD CommandLine /url "http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/Autodesk_Maya_2013_English_Japanese_SimplifiedChines... /SN 900-31520570 /PK 657E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/7/17:20:21:13 Samnold SAMNOLD === Setup ended ===
2014/7/17:20:21:10 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:20:21:10 Samnold SAMNOLD Launch
2014/7/17:20:21:11 Samnold SAMNOLD Download Skipped SETUP_CONFIG http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/SETUP_x64.tar...
2014/7/17:20:21:13 Samnold SAMNOLD PageOpen LaunchDialog
2014/7/17:20:41:13 Samnold SAMNOLD PageOpen LicenseDialog
2014/7/17:20:41:14 Samnold SAMNOLD PageOpen ProductInfoDialog
2014/7/17:20:41:15 Samnold SAMNOLD PageOpen ProductSelectionDialog2
2014/7/17:20:43:44 Samnold SAMNOLD PageOpen FullProgressDialog
2014/7/17:20:43:45 Samnold SAMNOLD Download Skipped DIRECTX http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/DIRECTX.tar.l...
2014/7/17:20:43:45 Samnold SAMNOLD Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Maya 2013\3rdParty\DirectX\DXSETUP.exe /silent
2014/7/17:20:50:56 Samnold SAMNOLD Install DirectX® Runtime Succeeded
2014/7/17:20:50:58 Samnold SAMNOLD Download Play Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:21:12:05 Samnold SAMNOLD Download Aborted Maya_Win http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/{635AC546-7CB1-4EED-81BA-BF131DC3FA9D}/Maya_Win_x64....
2014/7/17:21:12:05 Samnold SAMNOLD Install Autodesk® Maya® 2013 Failed Download Failed, Installation aborted, Result=1603
2014/7/17:21:12:08 Samnold SAMNOLD Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/7/17:21:12:10 Samnold SAMNOLD PageOpen InstallCompleteDialog
2014/7/17:21:16:36 Samnold SAMNOLD === Setup ended ===
2014/7/17:23:13:36 Samnold SAMNOLD === Setup started on SAMNOLD by Samnold ===
2014/7/17:23:13:36 Samnold SAMNOLD Launch
2014/7/17:23:13:36 Samnold SAMNOLD CommandLine /url "http://trial.autodesk.com/SWDLDDLM/2013/MAYA/WI/Autodesk_Maya_2013_English_Japanese_SimplifiedChines... /SN 900-31520570 /PK 657E1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
