plz find attached copy of my installation log... not able to complete installation of autodesk 3ds max 2013
Hi Stephen and welcome to the Discussion Forums!
Thank you for including the installation log, that was very helpful.
Please try manually installing the Microsoft .NET Framework 4 and then modifying the setup.ini file to remove the prerequisite check for .NET Framework.
Specific instructions on how to do so can be found in this error 1603 forum post (Thanks TravisNave!).
Please accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
Thank you!
