Installation & Licensing
external installer failed ??????
2 REPLIES 2
2002 Views, 2 Replies
i downloaded the 3-year student version of autocad 2011. when i try to install it, it gives the error"external installer stopped working"
2 REPLIES 2
jaich
TravisNave
Check your Windows Services and make sure that the Windows Installer service is not set to Disabled.
Then I would suggest you to unregister and re-register Windows installer, and check if it helps:
  1. Start > Run and type "msiexec /unreg", and then press ENTER.
  2. Start > Run and type "msiexec /regserver", and then press ENTER.
I would also suggest you to run System File Checker and see if it helps, here are the steps:
  1. Open a Command prompt (Start > Run and type CMD):
  2. type sfc /scannow
On Vista or Windows 7, you may need to run the Command prompt as Administrator
If all else fails, make sure you are running the latest Windows installer version.
Autodesk Forums:
Administrator Productivity
