Installation & Licensing
New Member
NitroPirate
Message 1 of 4 (3,411 Views)
errors installing mechanical 2011
3411 Views, 3 Replies
01-03-2011 01:59 PM
i am trying to install Autocad mechanical 2011 and i am getting the following errors;
ERROR:1324 the folder path 'My Pictures' contains an invalid charactor
click okay on that and then recieve the following two errors
Fatal error during installation #1191 failed to run AdskExecuteSequence.
Failed to initialize Autocad mechanical 2011.
any advice would be helpful, thank you!
Product Support
vivekramesh
Message 2 of 4 (3,371 Views)
Re: errors installing mechanical 2011
01-06-2011 12:14 AM in reply to: NitroPirate
The technical solution provides details on the Error 1324:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2885691&linkID=9240617
This error is also documented in the Microsift site below:
http://support.microsoft.com/kb/292582
Vivek Ramesh
Product Support Specialist
Global Services
Autodesk, Inc.
New Member
slgraybill
Message 3 of 4 (3,124 Views)
03-23-2011 12:37 PM in reply to: NitroPirate
We have noticed the same issue after a network install of AutoCad 2011 on Windows 7 x86.  Installation proceeds normally but when the user tries to open AutoCad the first time they receive the 1324 errors.  Our environment has all normal user folders (Documents, Pictures, Music, etc.) redirected to network storage.  The folder redirection is normally put in place by Group Policy
Evidently AutoCad does not support redirected folders that have a UNC path, which is a common occurance in businesses.  What we have done as a workaround is to run a reg file (attached here as a text file) that will restore all the logged in user's shell folder paths back to the Windows default.  After the registry file is successfully imported have the user start AutoCad and wait for it to fully initialize.
After AutoCad runs properly open a command prompt and type gpedit/force  This forces the user's profile to regain any Policy Objects put in by domain policy.  The user will need to log off and back on again but AutoCad should continue to run.
If you do not use Group Policy for these items and have it set under the local machine you should export these settings prior to running the registry file or you will need to manually recreate them.--my comments are specific to organizations using Group Policy Objects within a Windows domain structure.
Note that the above process needs to be performed for any user of a particular computer; it is not a global setting.  So far we have found this successful on several machines that previously we could not get AutoCad to initialize.
Stephen Graybill
PRO-TEC Coating Company
Member
bradleym
Message 4 of 4 (2,544 Views)
10-25-2011 08:37 AM in reply to: slgraybill
Stephen's advice worked like a charm for me. Thanks so much for posting the reg file.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
