Installation & Licensing
New Member
onfieldhelpdesk
Message 1 of 3 (781 Views)
errors AutoCAD LT 2012 and Windows 7 64 bit unable to install
781 Views, 2 Replies
12-28-2012 04:16 AM
i am having a lot of trouble installing Auto Cad LT 2012 on a 64bit windows 7 enterprise laptop. below is the log file . it contains something about DirectX Runtime Failed  and some other failures. please advice. i have also attached the full log file.
=== Setup started on USIND1N9278 by noelant ===
2012/12/12:11:55:28 noelant USIND1N9278 Launch
2012/12/12:11:56:29 noelant USIND1N9278 PageOpen LaunchDialog
2012/12/12:11:56:37 noelant USIND1N9278 PageOpen LicenseDialog
2012/12/12:11:56:40 noelant USIND1N9278 PageOpen ProductInfoDialog
2012/12/12:11:57:07 noelant USIND1N9278 PageOpen ProductSelectionDialog2
2012/12/12:11:57:10 noelant USIND1N9278 PageOpen FullProgressDialog
2012/12/12:11:57:10 noelant USIND1N9278 Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
2012/12/12:11:57:45 noelant USIND1N9278 Install DirectX Runtime Succeeded
2012/12/12:11:57:46 noelant USIND1N9278 Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\noelant\AppData\Local\Temp\_AID50A.tmp\Media.mst"
2012/12/12:11:57:46 noelant USIND1N9278 Install Autodesk Material Library 2012 Failed Installation aborted, Result=1625
2012/12/12:11:57:46 noelant USIND1N9278 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
pendean
Message 2 of 3 (772 Views)
Re: errors AutoCAD LT 2012 and Windows 7 64 bit unable to install
12-28-2012 05:29 AM in reply to: onfieldhelpdesk
Error code 1625 usually means your Windows log-in does not have sufficient rights for the install.
Error code 1619 is more generic but system related as well.
Did you remember to turn off UAC and your anti-virus software?
You can also search the installation forum for more tips: http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
TravisNave
Message 3 of 3 (758 Views)
12-28-2012 07:35 AM in reply to: onfieldhelpdesk
Dean is right.  1625 is a failure due to system policy restrictions.  Either you don't have sufficient privileges, or your domain rights are restricted by your Administrator.
If your IT allows, make sure you are installing with local admin rights, UAC off, and anti-virus disabled.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
