Installation & Licensing
Member
mrvser
Message 1 of 8 (774 Views)
error while installing the Autocad 2009 machnical on windows 64 bit system
774 Views, 7 Replies
04-02-2012 11:32 PM
Hi ,
i am helpdesk enggineer. i getting fatal error while installing autocad 2009 mechanical verison on windows 64 bit XP system. i attached snapshot for your reference which one  taken from autocad log.
pls help to resolve this.
2012/4/2:16:32:57 Administrator FMWS120269 === Setup started on FMWS120269 by Administrator ===
2012/4/2:16:33:16 Administrator FMWS120269 === Setup ended ===
2012/4/2:16:33:15 Administrator FMWS120269 === Setup started on FMWS120269 by Administrator ===
2012/4/2:16:35:14 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable Succeeded
2012/4/2:16:36:06 Administrator FMWS120269 Install Autodesk Design Review 2009 Succeeded
2012/4/2:16:36:14 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2012/4/2:16:36:42 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable Succeeded
2012/4/2:16:37:02 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2012/4/2:16:51:15 Administrator FMWS120269 Install .NET Framework Runtime 3.0 Succeeded
2012/4/2:16:51:22 Administrator FMWS120269 Install VBA (2627.01) Succeeded
2012/4/2:16:52:33 Administrator FMWS120269 Install DirectX 9.0 Runtime Succeeded
2012/4/2:16:52:50 Administrator FMWS120269 Install Windows Media Format 9.5 Succeeded
2012/4/2:16:53:07 Administrator FMWS120269 Install Microsoft WSE 3.0 Runtime Succeeded
2012/4/2:16:53:15 Administrator FMWS120269 Install AutoCAD Mechanical 2009 Failed Installation aborted, Result=1603
2012/4/2:17:13:59 Administrator FMWS120269 === Setup ended ===
TravisNave
Message 2 of 8 (741 Views)
Re: error while installing the Autocad 2009 machnical on windows 64 bit system
04-04-2012 09:06 AM in reply to: mrvser
You'll need to zip and attach the larger installation log file located in your %TEMP% folder. It will likely have more information on the reason for the failure.
Windows XP x64 was not exactly a home run OS.  But then again, you're installing AutoCAD 2009, which has been put to pasture.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
mrvser
Message 3 of 8 (721 Views)
04-06-2012 09:39 PM in reply to: mrvser
Hi
Member
mrvser
Message 4 of 8 (720 Views)
Hi
Member
mrvser
Message 5 of 8 (719 Views)
04-06-2012 09:44 PM in reply to: mrvser
Pls find the attached zip file . contains log files while installing autocad.
pls help me to resolve this issue....
Thanks.....
TravisNave
Message 6 of 8 (706 Views)
04-09-2012 07:28 AM in reply to: mrvser
It appears you are installing from an Administrative share.  Have you tried installing direct from disc?
New Member
merupesh_4all
Message 7 of 8 (693 Views)
04-10-2012 06:00 AM in reply to: mrvser
Same Problem with installing 2013 ...
TravisNave
Message 8 of 8 (676 Views)
04-11-2012 07:45 AM in reply to: merupesh_4all
Posting a screen cap of your failure is useless.  Please start a new thread and post the installation log file as it will explain the reason for the failure.  Most commonly, a prerequisite failed to install.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
