• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    error while installing the Autocad 2009 machnical on windows 64 bit system
    584 Views, 7 Replies
    04-02-2012 11:32 PM
    Hi ,
    i am helpdesk enggineer. i getting fatal error while installing autocad 2009 mechanical verison on windows 64 bit XP system. i attached snapshot for your reference which one  taken from autocad log.
    pls help to resolve this.
    2012/4/2:16:32:57 Administrator FMWS120269 === Setup started on FMWS120269 by Administrator ===
    2012/4/2:16:33:16 Administrator FMWS120269 === Setup ended ===
    2012/4/2:16:33:15 Administrator FMWS120269 === Setup started on FMWS120269 by Administrator ===
    2012/4/2:16:35:14 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable Succeeded
    2012/4/2:16:36:06 Administrator FMWS120269 Install Autodesk Design Review 2009 Succeeded
    2012/4/2:16:36:14 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
    2012/4/2:16:36:42 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable Succeeded
    2012/4/2:16:37:02 Administrator FMWS120269 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
    2012/4/2:16:51:15 Administrator FMWS120269 Install .NET Framework Runtime 3.0 Succeeded
    2012/4/2:16:51:22 Administrator FMWS120269 Install VBA (2627.01) Succeeded
    2012/4/2:16:52:33 Administrator FMWS120269 Install DirectX 9.0 Runtime Succeeded
    2012/4/2:16:52:50 Administrator FMWS120269 Install Windows Media Format 9.5 Succeeded
    2012/4/2:16:53:07 Administrator FMWS120269 Install Microsoft WSE 3.0 Runtime Succeeded
    2012/4/2:16:53:15 Administrator FMWS120269 Install AutoCAD Mechanical 2009 Failed Installation aborted, Result=1603
    2012/4/2:17:13:59 Administrator FMWS120269 === Setup ended ===
    Please use plain text.
    TravisNave
    Re: error while installing the Autocad 2009 machnical on windows 64 bit system
    04-04-2012 09:06 AM in reply to: mrvser
    You'll need to zip and attach the larger installation log file located in your %TEMP% folder. It will likely have more information on the reason for the failure.
    Windows XP x64 was not exactly a home run OS.  But then again, you're installing AutoCAD 2009, which has been put to pasture.
    Member
    04-06-2012 09:39 PM in reply to: mrvser
    Hi
    Member
    Hi
    Member
    04-06-2012 09:44 PM in reply to: mrvser
    Pls find the attached zip file . contains log files while installing autocad.
    pls help me to resolve this issue....
    Thanks.....
    TravisNave
    04-09-2012 07:28 AM in reply to: mrvser
    It appears you are installing from an Administrative share.  Have you tried installing direct from disc?
    New Member
    04-10-2012 06:00 AM in reply to: mrvser
    Same Problem with installing 2013 ...
    TravisNave
    04-11-2012 07:45 AM in reply to: merupesh_4all
    Posting a screen cap of your failure is useless.  Please start a new thread and post the installation log file as it will explain the reason for the failure.  Most commonly, a prerequisite failed to install.
    For more information about this process, please see my KB link here:
    http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
