Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
error when deploying Autocad 2012
- Highlight
- Email to a Friend
i try to deploy Autocad 2012 with Frontrange DSM. i found the instructions on appdeploy.com. i install directx, .net 4.0, FaroSDK (from Autodesk DVD), than acadmap.msi with mst and finally the language pack AcadMapLP.msi with mst. I receive an error during the installation of the language pack: Error 1606 could not access network location de-DE.
withouth this language package i can't start Autocad Map 3D 2012.
Re: error when deploying Autocad 2012
- Highlight
- Email to a Friend
Give this document a try
Error 1606: Could not access network location
http://usa.autodesk.com/getdoc/id=TS1059669
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
- Highlight
- Email to a Friend
thank you for your reply. i have the to regkeys and SYSTEM has full permissions on the keys.i get the error also when i start the msi manually
- Highlight
- Email to a Friend
With an MSI based install like Group Policies the two major things are to verify.
1. Make sure all the prerequisites are installed, before trying to deploy.
2. Make sure both MST's are applied to the two MSI packages.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
- Highlight
- Email to a Friend
requirements:
.net 4 installed
dirext x 11 installed
Microsoft Visual C++ 2008 Redistributable installed
i also tried to install both msi with the mst...
i don't understand the part of the application distribution share point, we don't have a central Server where every client can connect. we have many diffuse servers, so we must create a package for each server?
- Highlight
- Email to a Friend
You are missing a few other of the prerequisites like:
Microsoft Visual C++ 2005 Redistributable
Microsoft Visual C++ 2010 Redistributable
If you are on a 64-bit operating system you need the 32-bit and 64-bit versions of each of these installed.
There may be more prerequisites required by MAP that I am not aware of, would be best to get the full list from the support group.
I don't know anything about Frontrange or working with diffuse server's, so not sure if one of these is leading to the problems.
Can you push the deployment to a client from the original server you created the deployment to?
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
- Highlight
- Email to a Friend
i installed all prerequisites, map 3d 2012 is getting installed, the only problem is AcadMapLP.msi. i upload the logfile
- Highlight
- Email to a Friend
Looking at the log file it looks like there is a problem with your pathing specified and it cannot find one of the transform files.
Error applying transforms. Verify that the specified transform paths are valid. C:\Program Files\Common Files\enteo\RepositoryCache\104699\rev\1\Extern$\A
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
- Highlight
- Email to a Friend
yes i know but the file is there, i have the same error if i launch the msi with msiesxec /i MSI transforms=mst
- Highlight
- Email to a Friend
For your acadmap mst you should be using the one in the ..\AdminImage\x86\acadmap folder that is something like acadmap-<deploymentname>.mst, this should be used for both the main MSI and the langauge pack MSI as well as the gpo.mst from the ..\AdminImage\Tools folder.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
