2013/7/29:12:12:29 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:12:12:29 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:12:12:29 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/29:12:12:29 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:12:12:29 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/29:12:12:29 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI9679.tmp
2013/7/29:12:13:56 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:12:12:34 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:12:12:34 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:12:12:34 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI9679.tmp
2013/7/29:12:12:34 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:12:13:17 susan's laptop SUSANSLAPTOP-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/29:12:13:55 susan's laptop SUSANSLAPTOP-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/29:12:13:55 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AI9679.tmp\Setup\AcSetup.dll
2013/7/29:12:13:55 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/29:12:13:56 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/29:12:14:11 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/29:12:14:11 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/29:12:14:11 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/29:12:14:23 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/29:12:14:24 susan's laptop SUSANSLAPTOP-PC Download Play DOTNET4 http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/7/29:12:15:10 susan's laptop SUSANSLAPTOP-PC Download Complete DOTNET4 http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/7/29:12:15:10 susan's laptop SUSANSLAPTOP-PC Installing .NET Framework Runtime 4.0: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe" /q
2013/7/29:12:18:39 susan's laptop SUSANSLAPTOP-PC Install .NET Framework Runtime 4.0 Succeeded
2013/7/29:12:18:39 susan's laptop SUSANSLAPTOP-PC Download Skipped DOTNET4KB2468871 http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DO...
2013/7/29:12:18:39 susan's laptop SUSANSLAPTOP-PC Installing .NET Framework Runtime 4.0 KB2468871: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe" /q /norestart
2013/7/29:12:24:40 susan's laptop SUSANSLAPTOP-PC Install .NET Framework Runtime 4.0 KB2468871 Succeeded
2013/7/29:12:24:41 susan's laptop SUSANSLAPTOP-PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/29:12:24:46 susan's laptop SUSANSLAPTOP-PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/29:12:24:46 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/29:12:25:49 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/29:12:25:49 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:26:08 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:12:26:09 susan's laptop SUSANSLAPTOP-PC Download Play CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:26:29 susan's laptop SUSANSLAPTOP-PC Download Complete CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:26:29 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:27:23 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/29:12:27:23 susan's laptop SUSANSLAPTOP-PC Download Play CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:27:44 susan's laptop SUSANSLAPTOP-PC Download Complete CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:27:44 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:28:18 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:12:28:20 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:28:30 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/29:12:28:31 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:28:39 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/29:12:28:39 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:12:33:43 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:12:33:43 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/29:12:33:54 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/29:12:34:39 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/29:12:35:32 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:12:36:53 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/29:12:36:57 susan's laptop SUSANSLAPTOP-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:12:36:57 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/7/29:12:36:57 susan's laptop SUSANSLAPTOP-PC Rollback .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1619
2013/7/29:12:36:57 susan's laptop SUSANSLAPTOP-PC Rollback .NET Framework Runtime 4.0 Failed Installation aborted, Result=1619
2013/7/29:12:37:08 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/29:12:40:26 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:12:44:34 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:12:44:34 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:12:44:34 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/29:12:44:34 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:12:44:34 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/29:12:44:34 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AIF6C1.tmp
2013/7/29:12:44:41 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:12:44:37 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:12:44:37 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:12:44:37 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AIF6C1.tmp
2013/7/29:12:44:37 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:12:44:39 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/29:12:44:40 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AIF6C1.tmp\Setup\AcSetup.dll
2013/7/29:12:44:40 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/29:12:44:41 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/29:12:45:08 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/29:12:45:08 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/29:12:45:08 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/29:12:45:15 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/29:12:45:16 susan's laptop SUSANSLAPTOP-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/29:12:45:16 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/29:12:46:20 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/29:12:46:21 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:46:48 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:12:46:48 susan's laptop SUSANSLAPTOP-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:46:49 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:47:22 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/29:12:47:22 susan's laptop SUSANSLAPTOP-PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:47:22 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:48:05 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:12:48:06 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:48:21 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/29:12:48:22 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:48:33 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/29:12:48:34 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:12:51:37 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:12:51:37 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/29:12:51:48 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/29:12:52:38 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/29:12:53:32 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:12:54:45 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/29:12:54:49 susan's laptop SUSANSLAPTOP-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:12:54:49 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/7/29:12:54:53 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/29:12:55:12 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:12:55:35 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:12:55:35 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:12:55:35 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/29:12:55:35 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:12:55:35 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/29:12:55:35 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AIB89.tmp
2013/7/29:12:55:43 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:12:55:37 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:12:55:37 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:12:55:37 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AIB89.tmp
2013/7/29:12:55:37 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:12:55:40 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/29:12:55:42 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AIB89.tmp\Setup\AcSetup.dll
2013/7/29:12:55:42 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/29:12:55:42 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/29:12:55:52 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/29:12:55:52 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/29:12:55:52 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/29:12:55:59 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/29:12:56:00 susan's laptop SUSANSLAPTOP-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/29:12:56:00 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/29:12:56:58 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/29:12:56:58 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:58:51 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Failed Failure is ignored, Result=1603
2013/7/29:12:58:51 susan's laptop SUSANSLAPTOP-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:58:51 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:59:16 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/29:12:59:16 susan's laptop SUSANSLAPTOP-PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:12:59:16 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:59:35 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:12:59:37 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:59:50 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/29:12:59:50 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:12:59:56 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/29:12:59:57 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:13:03:15 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:13:03:15 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/29:13:03:22 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/29:13:03:48 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/29:13:04:23 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:13:05:33 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/29:13:05:33 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/7/29:13:05:35 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/29:13:05:49 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:13:07:03 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:13:07:03 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:13:07:03 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/29:13:07:03 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:13:07:03 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/29:13:07:03 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI8C2D.tmp
2013/7/29:13:07:09 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:13:07:05 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:13:07:05 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:13:07:05 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI8C2D.tmp
2013/7/29:13:07:05 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:13:07:07 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/29:13:07:08 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AI8C2D.tmp\Setup\AcSetup.dll
2013/7/29:13:07:08 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/29:13:07:09 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/29:13:07:23 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/29:13:07:23 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/29:13:07:28 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/29:13:07:28 susan's laptop SUSANSLAPTOP-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:13:07:29 susan's laptop SUSANSLAPTOP-PC Install Network License Manager Succeeded
2013/7/29:13:07:31 susan's laptop SUSANSLAPTOP-PC Download Play CADM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CA...
2013/7/29:13:07:39 susan's laptop SUSANSLAPTOP-PC Download Aborted CADM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CA...
2013/7/29:13:07:39 susan's laptop SUSANSLAPTOP-PC Install Autodesk CAD Manager Tools Failed Download Failed, Installation aborted, Result=1603
2013/7/29:13:07:39 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/29:13:07:51 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:13:08:10 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:13:08:10 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:13:08:10 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/29:13:08:10 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:13:08:10 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/29:13:08:10 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI9081.tmp
2013/7/29:13:08:15 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:13:08:12 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:13:08:12 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:13:08:12 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI9081.tmp
2013/7/29:13:08:12 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:13:08:13 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/29:13:08:13 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AI9081.tmp\Setup\AcSetup.dll
2013/7/29:13:08:13 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/29:13:08:14 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/29:13:08:22 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/29:13:08:22 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/29:13:08:22 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/29:13:08:25 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/29:13:08:26 susan's laptop SUSANSLAPTOP-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/29:13:08:26 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/29:13:09:30 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/29:13:09:30 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:13:09:47 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:13:09:47 susan's laptop SUSANSLAPTOP-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:13:09:47 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:13:10:21 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/29:13:10:21 susan's laptop SUSANSLAPTOP-PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:13:10:22 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:13:10:51 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:13:10:53 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:13:11:07 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/29:13:11:07 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:13:11:15 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/29:13:11:16 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:13:14:50 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:13:14:50 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/29:13:15:00 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/29:13:15:42 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/29:13:16:22 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:13:17:17 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/29:13:17:19 susan's laptop SUSANSLAPTOP-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:13:17:19 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/7/29:13:17:22 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/29:13:17:36 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:20:50:38 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:20:50:38 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:20:50:38 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/29:20:50:38 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:20:50:38 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/29:20:50:38 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AIF573.tmp
2013/7/29:20:50:49 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/29:20:50:41 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/29:20:50:41 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/29:20:50:41 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AIF573.tmp
2013/7/29:20:50:41 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/29:20:50:42 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/29:20:50:43 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AIF573.tmp\Setup\AcSetup.dll
2013/7/29:20:50:43 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/29:20:50:44 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/29:20:50:54 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/29:20:50:54 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/29:20:50:54 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/29:20:50:59 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/29:20:51:00 susan's laptop SUSANSLAPTOP-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/29:20:51:00 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/29:20:52:06 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/29:20:52:07 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:20:52:29 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:20:52:29 susan's laptop SUSANSLAPTOP-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:20:52:29 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:20:53:11 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/29:20:53:11 susan's laptop SUSANSLAPTOP-PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/29:20:53:12 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:20:53:44 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:20:53:46 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:20:54:02 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/29:20:54:02 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/29:20:54:08 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/29:20:54:10 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:20:58:06 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/29:20:58:06 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/29:20:58:26 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/29:20:59:14 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/29:21:00:17 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/29:21:02:25 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/29:21:02:27 susan's laptop SUSANSLAPTOP-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/29:21:02:27 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/7/29:21:02:29 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/29:21:03:06 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/30:09:52:52 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/30:09:52:52 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/30:09:52:52 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/30:09:52:52 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/30:09:52:52 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/30:09:52:52 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI298F.tmp
2013/7/30:09:52:59 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/30:09:52:54 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/30:09:52:54 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/30:09:52:54 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI298F.tmp
2013/7/30:09:52:54 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/30:09:52:56 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/30:09:52:57 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AI298F.tmp\Setup\AcSetup.dll
2013/7/30:09:52:57 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/30:09:52:58 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/30:09:53:08 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/30:09:53:08 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/30:09:53:08 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/30:09:53:15 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/30:09:53:15 susan's laptop SUSANSLAPTOP-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/30:09:53:15 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/30:09:54:22 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/30:09:54:23 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/30:09:54:43 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/30:09:54:43 susan's laptop SUSANSLAPTOP-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/30:09:54:44 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/30:09:55:18 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/30:09:55:18 susan's laptop SUSANSLAPTOP-PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/30:09:55:18 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/30:09:55:49 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/30:09:55:50 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/30:09:56:04 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/30:09:56:05 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/30:09:56:15 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/30:09:56:16 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/30:09:59:40 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/30:09:59:40 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/30:09:59:49 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/30:10:00:33 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/30:10:01:18 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/30:10:02:29 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/30:10:02:30 susan's laptop SUSANSLAPTOP-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/30:10:02:30 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/7/30:10:02:31 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/30:10:11:56 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/31:13:06:07 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/31:13:06:07 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/31:13:06:07 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/31:13:06:07 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/31:13:06:07 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/31:13:06:07 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI585C.tmp
2013/7/31:13:06:12 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/31:13:06:10 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/31:13:06:10 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/31:13:06:10 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI585C.tmp
2013/7/31:13:06:10 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/31:13:06:11 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/31:13:06:11 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AI585C.tmp\Setup\AcSetup.dll
2013/7/31:13:06:11 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/31:13:06:11 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/31:13:06:25 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/31:13:06:25 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/31:13:06:25 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/31:13:06:46 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/31:13:06:46 susan's laptop SUSANSLAPTOP-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/31:13:06:46 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/31:13:08:01 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/31:13:08:01 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:13:08:18 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/31:13:08:18 susan's laptop SUSANSLAPTOP-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/31:13:08:18 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:13:08:56 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/31:13:08:56 susan's laptop SUSANSLAPTOP-PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/31:13:08:56 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:13:09:16 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/31:13:09:17 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:13:09:29 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/31:13:09:29 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:13:09:37 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/31:13:09:38 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/31:13:14:31 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/31:13:14:31 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/31:13:14:45 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/31:13:16:23 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/31:13:17:33 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/31:13:19:11 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/31:13:19:16 susan's laptop SUSANSLAPTOP-PC Rollback FARO LS 5.1.0.30630 (64bit) Succeeded
2013/7/31:13:19:16 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2013/7/31:13:19:17 susan's laptop SUSANSLAPTOP-PC PageOpen InstallCompleteDialog
2013/7/31:13:20:24 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/31:16:22:59 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/31:16:22:59 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/31:16:22:59 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Autodesk\AutoCAD_2014_English_Win_32_64bit_wi_en-us
2013/7/31:16:22:59 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/31:16:22:59 susan's laptop SUSANSLAPTOP-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/AutoCAD_2014_English_Win_32_64bit_wi_en-u... /SN 900-40350112 /PK 001F1 /student /skipEULA /akamai /auth /sid
2013/7/31:16:22:59 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI96B6.tmp
2013/7/31:16:23:06 susan's laptop SUSANSLAPTOP-PC === Setup ended ===
2013/7/31:16:23:01 susan's laptop SUSANSLAPTOP-PC === Setup started on SUSANSLAPTOP-PC by susan's laptop ===
2013/7/31:16:23:01 susan's laptop SUSANSLAPTOP-PC Path_Length: 155
2013/7/31:16:23:01 susan's laptop SUSANSLAPTOP-PC Current Directory C:\Users\SUSAN'~1\AppData\Local\Temp\_AI96B6.tmp
2013/7/31:16:23:01 susan's laptop SUSANSLAPTOP-PC Launch
2013/7/31:16:23:02 susan's laptop SUSANSLAPTOP-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/SE...
2013/7/31:16:23:05 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\SUSAN'~1\AppData\Local\Temp\_AI96B6.tmp\Setup\AcSetup.dll
2013/7/31:16:23:05 susan's laptop SUSANSLAPTOP-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/7/31:16:23:06 susan's laptop SUSANSLAPTOP-PC PageOpen LaunchDialog
2013/7/31:16:23:14 susan's laptop SUSANSLAPTOP-PC PageOpen LicenseDialog
2013/7/31:16:23:14 susan's laptop SUSANSLAPTOP-PC PageOpen ProductInfoDialog
2013/7/31:16:23:14 susan's laptop SUSANSLAPTOP-PC PageOpen ProductSelectionDialog2
2013/7/31:16:23:18 susan's laptop SUSANSLAPTOP-PC PageOpen FullProgressDialog
2013/7/31:16:23:19 susan's laptop SUSANSLAPTOP-PC Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/DI...
2013/7/31:16:23:19 susan's laptop SUSANSLAPTOP-PC Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/7/31:16:24:22 susan's laptop SUSANSLAPTOP-PC Install DirectX Runtime Succeeded
2013/7/31:16:24:37 susan's laptop SUSANSLAPTOP-PC Installing FARO LS 5.1.0.30630 (64bit): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:16:25:27 susan's laptop SUSANSLAPTOP-PC Install FARO LS 5.1.0.30630 (64bit) Failed Failure is ignored, Result=1603
2013/7/31:16:25:27 susan's laptop SUSANSLAPTOP-PC Download Skipped CM http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/31:16:25:28 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:16:25:49 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 Succeeded
2013/7/31:16:25:50 susan's laptop SUSANSLAPTOP-PC Download Skipped CMILB http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/CM...
2013/7/31:16:25:51 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:16:26:19 susan's laptop SUSANSLAPTOP-PC Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/31:16:26:20 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\Autodesk AutoCAD 2014\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x86),.NET Framework Runtime 4.0,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:16:26:27 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Succeeded
2013/7/31:16:26:27 susan's laptop SUSANSLAPTOP-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® AutoCAD® 2014" SETUP_PACKAGECODE={D54FD115-F651-4237-B57C-E4230340EAB6} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/7/31:16:26:33 susan's laptop SUSANSLAPTOP-PC Install Autodesk Content Service Language Pack Succeeded
2013/7/31:16:26:34 susan's laptop SUSANSLAPTOP-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/31:16:29:15 susan's laptop SUSANSLAPTOP-PC Download Aborted ACAD http://studentsdownload.autodesk.com/SWDLDNET3/2014/ACD/WI/{64CFA19F-6192-4CD5-AA9E-77334D584BE2}/AC...
2013/7/31:16:29:16 susan's laptop SUSANSLAPTOP-PC Install Autodesk® AutoCAD® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/7/31:16:29:27 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Language Pack Succeeded
2013/7/31:16:29:58 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Content Service Succeeded
2013/7/31:16:30:36 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/7/31:16:31:49 susan's laptop SUSANSLAPTOP-PC Rollback Autodesk Material Library 2014 Succeeded
2013/7/31:16:31:49 susan's laptop SUSANSLAPTOP-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Hi Susan!
Can you please check out the following 1603 solutions and let me know if any of them do the trick?
Looks like the problem is actually in the download portion. It is not completing.
You might have to download the trial or get it from Matt, the virtual assistant.
