• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    error installing inventor 2013
    112 Views, 1 Replies
    12-03-2012 08:13 AM
    2012/12/3:16:59:35 Gregor Švigelj GREGA Install Autodesk Material Library 2013 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
    2012/12/3:16:59:35 Gregor Švigelj GREGA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
    2012/12/3:16:59:48 Gregor Švigelj GREGA Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
    2012/12/3:17:00:11 Gregor Švigelj GREGA Rollback Autodesk Material Library 2013 Succeeded
    2012/12/3:17:00:11 Gregor Švigelj GREGA Rollback .NET Framework Runtime 4.0 KB2468871 Failed Failure is ignored, Result=1619
    2012/12/3:17:00:11 Gregor Švigelj GREGA Rollback .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1619
    I cannot install inventor, i dont know whats the matter?
    please help me, thank you.!
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: error installing inventor 2013
    12-03-2012 02:01 PM in reply to: svigelj.gregor
    It's not able to complete the download of the libraries.  Make sure you have a solid internet connection and that you are not using any blocking software to impede you, like Norton Internet Security, etc.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
