Installation & Licensing
Member
jboyd2107
Message 1 of 6 (294 Views)
error installing AutoCAD 2013
294 Views, 5 Replies
10-30-2013 01:29 PM
I'm a student and I am having trouble installing autocad 2013. In particular, I am unsure how to resolve the repeating failure of directx runtime during installation. Also, during installation an error box appears detailing the failure of FNP_Act_Installer.dll 3: 5. I have tried multiple sollutions listed online for both the issues above to no resolve. I have also, among other things, tried installation during diagnostic mode on my computer. I am operating on Windows 7 Home Edition, 32-bit. Please help. Attached is the most current setup log.
Member
jboyd2107
Message 2 of 6 (273 Views)
Re: error installing AutoCAD 2013
10-30-2013 07:21 PM in reply to: jboyd2107
bump
Product Support
dembkod
Message 3 of 6 (254 Views)
10-31-2013 08:09 AM in reply to: jboyd2107
jboyd2107 ,
Hello. If you look at the log file in your temp directory- open it and search on the word “failed”.
You may see this connected to particular prerequisites. If you see this, I would target those programs and uninstall them before I ran my next installation.
Also, run the MSFixit utility to try and uninstall. Also turn off your Antivirus and login as an admin before you install.
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Thank you for taking part in our community!
David Dembkoski
Member
jboyd2107
Message 4 of 6 (246 Views)
10-31-2013 09:02 AM in reply to: jboyd2107
OK. I've looked through the install log in the temp folder and found that the only instance of "failed" during the installation occurs when the program attempts to load the "FNP_ACT_InstallerCA.dll 3: 5" file. I have also turned off all ant-virus software and run the install as an administrator. What should I do to overcome this particular installation error?
Member
jboyd2107
Message 5 of 6 (237 Views)
10-31-2013 06:48 PM in reply to: dembkod
bump
Product Support
frederic.bernabo
Message 6 of 6 (223 Views)
11-01-2013 03:29 AM in reply to: jboyd2107
Here is a technical article with the most common 1603 error
http://usa.autodesk.com/getdoc/id=TS22132908
You might having a look.
Keep in mind when installing your Autodesk product to turn off UAC
http://support.microsoft.com/kb/975787
and disable your antivirus, check the processes with your task manager to be sure it's really disabled.
Frederic
Frédéric Bernabo
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
