Installation & Licensing
error during registration
2 REPLIES 2
HarfordHabitat
395 Views, 2 Replies
I am trying to register AutoCAd 2010.  We have 2 disc sets.  I was able to register disc 1 sucessfully.  When I enter the 2nd disc an error message says the serial number is registered to a different company.  Now what do I do?
SN XXX-XXXXXXXX
This post has been editied to remove the Sertial Number and Activation Code.
2 REPLIES 2
in reply to: HarfordHabitat
contact your reseller to know to what exactly name is used for company to that serail number.
Perhaps an error occured during the registration of the product.
You can use this form also to contact Autodesk directly.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13682581
TravisNave
Franck is right. I checked the registration before the Admin removed the serial number (never ever ever ever ever post your serial number) and it is *not* registered to Hartford Habitat for Humanity.  For security purposes, I cannot tell you the registrar.  If this was purchased from another organization, you might need to fill out a TOL with the reseller to show that you are the new owner of the license.  Only your reseller can help you with this issue.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
